Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - oil in spark plug tubes 4AFE
View Single Post
Old 06-02-2006, 03:47 PM   #8 (permalink)
uncle-vinny
uncle-vinny
View uncle-vinny's Photo Gallery
Originally Posted by Carvin'07 Yaris
It may just be as simple as checking the gasket on your oil filler cap on top of the valve cover. Is it possible that the oil gets in from there? I cannot recall as I only owned a 2000 Corolla before. What about the valve cover itself? Are you doing the reinstallation so that you can see that due care is being taken?
Good luck.
I have checked the oil filler cap frequently and there is no oil leaking out of it. The valve cover was installed with a new gasket and sealer used as recommended by the Toyota shop manual. New gromments were installed under the hold down nuts and the nuts were torqued to manual specs.
uncle-vinny is offline   Reply With Quote
