Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Supra seats fit AE92???
View Single Post
Old 06-04-2006, 12:07 AM   #2 (permalink)
cuzman
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
those seats are gourgoues! (fully nice) so you recon ther out of a supra ..nice call
anything fits just use your rails and eather
a) bolt straight in or
b) mod your rail holes.or the seat mount holes .should just be a drill job!
WE all know seats are about the same width and im sure toyo doesnt like to make more parts than needed..
I know what ya asking and im not sure.... but front to back the rails are adjustable as once the front is bolted on the rear guides are independant and operate via a wire setup with is easily moved forward or back to fit....when you pull the lever to move the seat base forward or back the rear mount is operated by wire! this can very easily be changed to suit!
its the width of the mounts thats the issue..i would sa you could get a way with a 5 mill diff each side and drill and bolt ..just use a thick washer made to with stand impact forces
eg if ya get rear ended you dont whant the seat to pull away!
I did a seat convesion awhile ago in a different make and to get it legit they were very strick on the bolts and washers used!
If this bolts in well sweet as i'd love a pair and we have heaps around here..
ANy body done tis?
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
