Re: Now, onto the alarm
"Hachiroku" <Trueno@ae86.GTS> wrote in message
news:juFgg.588$qo4.463@trndny05...[color=blue]
> On Wed, 31 May 2006 11:42:53 -0500, Ray O wrote:
>[color=green]
>> news:tbjfg.42$_F6.38@trndny03...[color=darkred]
>>><snipped>
>>> Oh, hay, I got a question for you.
>>> I chased the wire from the Driver's door back to the Fuse block, tapped
>>> into it, and the alarm works Just Fine...
>>> from the Driver's door.
>>> I am assuming there is some function from the Driver's door grounding
>>> switch that is NOT activated by the passenger's door.
>>> On all my other Toyotas, I have followed this wire back to the fuse
>>> block,
>>> tapped into it and had no problem. On one car it even activated when the
>>> hatch was opened.
>>> So, I need to find a grounding connection common to both doors; possibly
>>> the dome light.[/color]
>> I would use the dome light circuit because it does both doors and I think
>> it
>> also does the hatch.[/color]
> I was looking for it! Any idea where it might be? Or, what color wire am I
> looking for?
> The paper I dl'd from the internet gave the colors for the doors, but for
> "Dome Light Supervision", it said "none"
>[/color]
Sorry, off the top of my head, I have not idea what color or where the dome
light wires might be. you can pull the dome light assembly to see what
color the wires are, and then look at the bottom of the driver's side
A-pillar and see if you can find it.
Ray O
