1982 Wiper issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Corona Forum Specific discussion of the Toyota Corona
Old 12-02-2007, 04:07 PM   #1 (permalink)
View Clockfxr's Photo Gallery
1982 Wiper issues
I had a water leak in my '82 Corona sedan, and now the wipers are on the fritz. I opened up the wiper control module and found water had flooded part of the module. I replaced all capacitor and resistors that were submerged, also pulled open the wiper switch to check that out too. Still, I only have high speed. Are there any other modules, etc., that control wiper speed? Help really needed.
Clockfxr is offline   Reply With Quote
Old 12-02-2007, 09:35 PM   #2 (permalink)
View gaijin71's Photo Gallery
i don't think there'd be another module to control wiper speed. wiper relay perhaps? what's the part number of the module?
gaijin71 is offline   Reply With Quote
Old 12-03-2007, 11:19 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $220590
View Doctor J's Photo Gallery
The wiper module controls delay on Int function.
The speed of the motor is controlled by supplying power to the selected brush (the motor has 3 brushes) one negative, one positive low speed and one positve high speed; the low speed brush is located directly opposite to the negative brush.
First backprobe the connector at the motor and verify that there is a power available at high speed terminal.(You may have to use the wiring schematics for this,) Hope this helps
Doctor J is offline   Reply With Quote
96 Camry Wiper Relay DD 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-02-2008 03:50 PM
92 le Wiper problem (advice needed) mikerowesoft 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-12-2007 10:32 AM
1982 Cressida Timing Chain Issues triver525 Cressida Forum 3 08-30-2006 05:03 PM
Help (wiper arm) tekkam Archived Corolla threads 0 09-26-2005 11:04 PM
89 camry wiper question dallison 1st & 2nd Generation (1983–1986 & 1987-1991) 2 02-15-2004 02:35 AM
