'79 Corona tune-up - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Corona Forum Specific discussion of the Toyota Corona
Old 08-28-2008, 10:39 AM   #1 (permalink)
View micwalk1's Photo Gallery
'79 Corona tune-up
Recently purchased a '79 Corona. The cat was removed and the O2 sensor left. I have no diagrams to tell me how the O2 sensor affects performance--other than a general idea based on theory. I'm considering installation of a new convertor and O2 sensor. Would like to know if there are other options.
micwalk1 is offline   Reply With Quote
Old 08-28-2008, 04:34 PM   #2 (permalink)
bilt not bot
View shonuff's Photo Gallery
the O2 sensor doesnt do much at all.
just tells the smog equipment to choke down the eng from time to time.
it is supposed to be after the cat, usually there is a fitting on the end of the cat for it.
no real reason to buy a new 02 sensor just use the one that came with the car, if its really gunked up you could clean it, but its no where near as touchy or important as one on a efi car.
its like a dummy light for emissions
www.youtube.com/nuffbilt
shonuff is offline   Reply With Quote
Old 09-09-2008, 01:35 PM   #3 (permalink)
Old cars are my destiny
79Corona's Avatar
View 79Corona's Photo Gallery
It causes a diverter valve to switch air pump air into the exhaust stream to cool the converter depending on the mixture needed. I had to replace the converter because the flanges were rusted badly. If your air pump system is not functional or removed, the converter will likely only work partially correct. Frankly I don't think it's that important, but I was told it was illegal to remove them.
Bryan
86 Hilux LE longbed
Other Toyotas : 79 Corona DLX sedan (Mint green), 89 Corolla DX sedan (wine), 88 Camry V6 LE sedan (blk), 86 Hilux std bed (wine), 82 Celica GT hatchback (bwn), 78 Celica GT coupe (slvr), 76 Corolla SR-5 coupe (wht)
79Corona is offline   Reply With Quote
Old 09-03-2009, 06:39 AM   #4 (permalink)
Daddy NS
Daddy NS's Avatar
View Daddy NS's Photo Gallery
1979 Corona
Hi MicWalk1,
What is the engine of your '79 Corona?
I have a '79 Corona Wagon and it is mounted with a 12RM engine, it's entire system is quite simple and conventional, none of those complicated looking links of rubber hoses and vacuum stuffs..
I'm looking for options and I'm open to suggestions as to how I can further more reduce my emissions, a head shave to increase compression is one of the suggestions.
Good day!
Daddy NS is offline   Reply With Quote
