Updated pics of my 14kmiles 77' Corona.... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Corona Forum Specific discussion of the Toyota Corona
Old 10-13-2008, 01:46 AM   #1 (permalink)
View superboosted's Photo Gallery
Well,just figured I would show it off,she is almost ready to pull out of the garage,if only I could get the clutch master to bleed
Started...
2 weeks later...
Man I love this car...now just to get the weber tuned/exhaust built and lower her!
superboosted is offline   Reply With Quote
Old 10-15-2008, 06:10 PM   #2 (permalink)
bilt not bot
View shonuff's Photo Gallery
looking good
if you pull the rubber plugs out from under the louvers they will actually function, on my wagon i even cut out a lil of the hood to make a bigger opening.
if you cant bleed the clutch slave make sure you've bench bled the master correctly.
www.youtube.com/nuffbilt
shonuff is offline   Reply With Quote
Old 10-15-2008, 08:06 PM   #3 (permalink)
I ordered all new stuff,lines,master and slave,as I am not taking chances-she has not been on the road since 88'
Bench bleed?Tell me more...
Old 10-16-2008, 08:25 PM   #4 (permalink)
bilt not bot
you basicly install some plugs where the line goes on the master.
fill the res with fluid
then pump
after the bubbles stop, press the pedal as far as it will go and "bump" it there at the bottom without coming all the way back until bubbles stop coming up in the res.
hook the line back up and dont let the res run dry while you swap the plug for the line.
once the lines and slave are hooked up, open the bleeder valve on the slave. gravity "should" slowly bring fluid down the line. if it doesnt pump the pedal a few times to get it started, again dont let the res run dry.
then bleed the slave, when thats done go back to the line connection on the master and bleed there to make sure there is no more air in the system.
Old 10-19-2008, 04:03 PM   #5 (permalink)
Old cars are my destiny
79Corona's Avatar
View 79Corona's Photo Gallery
How much difference are the headers with the Weber vs the stock exh manifold? Nice looking car, would you mind uploading the pic to the forum gallery? Thanks.
Bryan
86 Hilux LE longbed
Other Toyotas : 79 Corona DLX sedan (Mint green), 89 Corolla DX sedan (wine), 88 Camry V6 LE sedan (blk), 86 Hilux std bed (wine), 82 Celica GT hatchback (bwn), 78 Celica GT coupe (slvr), 76 Corolla SR-5 coupe (wht)
79Corona is offline   Reply With Quote
