glad ya came on over here
now this reply is based of this thread and the thread over @
http://www.classic-celica.com/module...wtopic&t=17460
note to class: his flywheel bolts sheared off
i would try the easy outs again, but i would also heat up the crank with a torch first.
i would also just pull the eng. your just a few bolts and hoses from it coming out anyway. you might get lucky and the machine shop can take em out if ya bring em the whole eng.
tranny wise, instead of swapping to a w50, swap to a W58 out of a 82-85 celica, its the same as the W50 cept its made out of aluminum.
for the rear end, check the build plate next to the wiper motor for the "trans axle" code. 2nd line from the bottom. that will tell you what rear end you have. the first letter is what i mean by "T code".
and then cuz you have a 74 you have the same suspension as the hilux from 72-78 so any of those rears will work but it will be 5 lug, but like i said the fronts are super easy to swap to 5 lug. the leaf sprung hiace or a slightly newer corona axl is going to be your best shot for a 4 lug rear axl thats a lil bigger. some older corolla's had leafs in the back as well. any axl newer then 85 might have width issues, so i cant really say not knowing the newer dimensions off hand. you want to find a axl that has the code "Fxxx" (x=#) thats a 7.5 in diff and then you can swap a LSD from a 82-86 supra into the third memeber for a oem LSD.
finnally the louvers on your hood should come off with a couple nuts hidden under some rubber plugs on the under side of the hood. they are made out of aluminum and covered in paint.
love your F'n bumpers by the way
