Carbureator help please. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Corona Forum Specific discussion of the Toyota Corona
Old 07-22-2009, 04:04 PM   #1 (permalink)
View URIELFIVE's Photo Gallery
Question Carbureator help please.
This is a bit embarassing as I own an automotive shop that specializes in high end cars, Unfortunatly in the many years I have in the automotive buissiness I have never had the privilage in working on a carbureator. My 68 Corona started giving me a little idle problem and after sitting for a few weeks wouldnt start unless i tapped the top of the carbureator. I tried to open it up to see if it was just dirty inside or something was sticking, but the top screws are all stripped! I decided to get a rebuilt carb online. I recived it and installed it but now Im not sure how to adjust it. After installing it the car revs too high and I dont want to mess it up. Any help would be appreciated.
Thank You Uriel
URIELFIVE is offline   Reply With Quote
Old 07-22-2009, 07:14 PM   #2 (permalink)
View Carl H's Photo Gallery
Thank You Uriel
Hi, if your carb has an automatic choke you fast idle screw may need to be adjusted. But when the motor is warmed up , it still idles high you need to turn the idle stop screw.This is the screw that stops the butterfly from closing too much, look at your old carb if you have it to see where the screw (s) are located. You may need to check the float level and also the idle mixture air screw . emember what screw you turned and how much, so you can go back to the way it was if things aren't working out. CH
Carl H is offline   Reply With Quote
Old 07-25-2009, 10:40 AM   #3 (permalink)
Old cars are my destiny
79Corona's Avatar
View 79Corona's Photo Gallery
Sounds like the float valve could be stuck.
Bryan
86 Hilux LE longbed
Other Toyotas : 79 Corona DLX sedan (Mint green), 89 Corolla DX sedan (wine), 88 Camry V6 LE sedan (blk), 86 Hilux std bed (wine), 82 Celica GT hatchback (bwn), 78 Celica GT coupe (slvr), 76 Corolla SR-5 coupe (wht)
79Corona is offline   Reply With Quote
Old 07-31-2009, 08:49 AM   #4 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547555
View fourwd1's Photo Gallery
I used to have a similar problem with my old 81 Corona. It was just crap in the bowl clogging the needle valve. You have to expect that sort of thing in a vehicle with several decades on it
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
