Here I am, the proud owner of a 1980 Toyota Corona 4 door hatchback. I just trailored it home this past weekend. This is a one owner car with 89k - it's been sitting in a garage the last three years without being driven. Overall condition is a 10 out of 10 - not a blemish anywhere. My question for you experienced owners relates to what to do before putting it back on the road - I purchased this vehicle for my 18yr old daughter - the question relates to:
Fluids - can I use synthetics in everything? rearend, auto tranny, motor oil?
Gas - Do I need to drain the gas tank (it's almost full) or can I treat it with something?
Radiator appears to be dry - are there known issues with this?
Appears to be quite a bit of oil underneath the car - especially for only having 89K miles - are there known issues with seals?
Should I do wheel bearings?
Obviously I need to check brakes, replace tires etc - I guess I'm looking for the things I need to do for this jewell to run another 100K...
Thanks for your time and consideration!
