20/22R Hybrid Power '81 Corona (many pics) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Corona Forum Specific discussion of the Toyota Corona
Old 10-18-2009, 03:11 PM   #1 (permalink)
JoeDirtMcD3's Avatar
View JoeDirtMcD3's Photo Gallery
20R 22R Hybrid Power '81 Corona (many pics)
I've been through a whole heck of a lot with Todd, our family (multi-generational) owned, 1981 Toyota Corona Luxury Edition. Among one of the few final US offered Corona's, this one has made it through my grandfather, my dad, my sister, and still working for me. Not to say it hasn't had its problems. It's been through several 22R motors, probably due to poor build quality or maybe I just beat it too much, not sure. The car just recently passed the 300,000 mile mark and now is around 302k.
Over the years, the top end has seen different configurations including an electric supercharger (that did nothing except maybe hinder performance) and a modified Weber 38/38 coupled to a 22R intake and an overdrilled cast aluminum adapter/riser plate that leaked air substantially (never ran right). More recently its had a new 22R long block installed by me and the automatic transmission was rebuilt a couple years ago. This car really would benefit from a manual transmission (w58 swap) though, which may come in the future if the unibody doesnt rust apart too much more...
AS FOR THE 20/22R HYBRID title...
After much mental debate over what to do for some actual power in my Corona, I decided to try the hybrid 20/22R route and see where it landed me. Prior to this I had considered a 2jzgte, a 7mge, a Nissan SR20DET, and a 22RTE. Since its a rare classic toyota automobile and technically still owned by my father, maintaining the stock engine and drivetrain is of importance.
So far, I have been acquiring parts bit by bit and still have a few important things to buy before I'm ready to take the car down for a couple days.
FIRST, I purchased a used intake manifold meant for a 1976 1977 TOYOTA CELICA with a 20R. Picked it up with a winning bid of $10.50 and shipped to Central Pennsylvania from CANADA for $25.00. It looked like the following on ebay:
As you can see in the pictures above and below, these older 20R intake manifolds have no provision for the EGR tube that is found on the 22R intakes next to the carburetor surface. This 'should' help improve velocity/flow because there will be less tendency for the intake mixture to flow in a direction other than towards the intake runners and should cause less turbulence directly below the carb. It should also allow for a cleaner install on the intake side of the motor.
When I got it home I took some pictures just to document it.
Some other things to note about this manifold that I don't remember from the 22R manifold include the coolant channels that flow up to the base of the carb and, with an intermediate plate, allow coolant to surround the base of the carburetor. These two channels will be plugged on the bottom side of the manifold in an attempt to stop the coolant flow to the base of the carb and possibly keep the mixture cooler and denser - also avoid a possible coolant leak in the future. I am worried, however, that the channels actually helped keep the carb cooler as the manifold soaks up heat while the engine is running. Honestly, I dont think that what I do either way will make much of a difference, but I am going to plug them anyway. Also, the fitting that was located at the bottom of the manifold on the 22R intake that allowed coolant to bypass the thermostat is located at the top of the 20R manifold.
I then proceeded to clean it up a little bit as I looked for a good deal on a Weber carb and 20R head as well as some other miscellaneous things and performance parts. The manifold was terribly corroded and dirty, many of the plugs and sensors were really seized in their threads. I finally got them out and took the manifold over to the parts cleaner at work. It helped a little but didnt do too much, could've done the same with some engine degreaser or brake cleaner. What really helps in these situations are steel wire brush wheels for DREMELs or rotary tools. They work great and can get into small spaces for the most part.
This is where I made my next mistake. I have a problem with polishing aluminum, an obsession perhaps. I decided I would sand down a section on the bottom of the manifold and see how it looked so I could decide if I wanted to do the whole manifold. Normally after cleaning the manifold, I would just paint it with some silver Dupli-Color wheel paint (it adheres better than the high temp stuff that I've tried in the past). Anyway, I liked the section I did so I made it bigger and polished it up. Before I knew it, I was sanding the entire manifold with sanding bits in my dremel. Two days later and my weekend is over and I'm at a break point, I've lost interest in polishing. I will finish though, no worries.
So I still have alot of sanding and polishing to do, not to mention some aluminum removal from the base of the carburetor mount and I might blend the aluminum into a more rounded opening towards the intake runners rather than the sharp cutoff that it is now. Unfortunately, the downdraft Weber 32/36 sitting on top of the two Redline adapter plates will cause the intake mixture to slam into the bottom of the manifold and lose a fair amount of velocity that it will try to regain as it makes the 90 degree turn. I just recently started thinking about implementing some aluminum plates at the bottom of the intake that kind of curve the mixture to the front and rear runners... more on that later.
In case I didn't mention, I bought one of the Weber 32/36 to 20/22R manifold kits from ebay for $249.99. Came very complete, or so it looks so far. Won't know what I'm missing until the final install of course. I wasn't satisfied with the hardware supplied or the rusted bolts that came with my manifold, so I went on a Stainless Steel fastener spree at the local hardware store and picked up some more visually appealing stuff. I like it shiny...
I'll probably edit this post at some point when I realize what I forgot to write. Let me know if you have any questions about what I'm doing. Hope this is interesting to someone other than just me....
JoeDirtMcD3 is offline   Reply With Quote
Old 10-19-2009, 10:33 AM   #2 (permalink)
DeBadged
Raffaelli's Avatar
View Raffaelli's Photo Gallery
Bravo!
Nice start. Ive built a 22/20R hybrid also and its well worth it. I hogged out both the intake and the head a bunch and thats easy to do too.
Just make shure the 20R head you get has a power steering boss(if you need it)
RN 44 Magnum
Raffaelli is offline   Reply With Quote
Old 10-19-2009, 11:36 AM   #3 (permalink)
I know Raffaelli, you were the one who convinced me to do this project. Do you run a Weber 32/36? If so did you re-jet it or anything? I'm tired of being so slow with my stock 22r. I really hope this whole project gains me some much needed horsepower. I just purchased a 20R head from an ebay store in Spokane, WA that is supposed to have the fuel pump slot and power steering mounts. I hope it gets here soon. I'm also looking into an adjustable timing gear but having doubts on whether its worth it.
I'm also going to install a billet aluminum wedge in the center of the 20r intake to help route the fuel mixture to the front and rear runners and hopefully gain a few extra ponies (more like 1 if I'm lucky).
Old 10-19-2009, 01:27 PM   #4 (permalink)
DeBadged
Raffaelli's Avatar
Ive got the 22r carb. There is a SOLID 10-15 hp left from a weber. I would probably get a 38DGEV.
If you have the 100 bucks, the adjustable timing sprocket would be well worth it. Advancing the cam would help bring the RPM range down, since a 20R head will flow more than the rods could take.
Heck, Im still running the stock carb, exhaust manifold, valves and cam. I know some more money would free it up even more.
RN 44 Magnum
Old 10-23-2009, 04:10 PM   #5 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
nice project you got going. all that polishing will make it easier to clean later. keep us posted on your progress
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 10-23-2009, 10:41 PM   #6 (permalink)
Yeah thanks, it should make things easier to keep clean - I hope. I hope it doesn't become a thing that I have to constantly polish to keep from oxidizing. On to the progress: Like I said, I ordered a rebuilt 20R head from ebay seller that should arrive Monday (10/26/09). I'm not going to worry about an adjustable timing gear or double row timing chain for the "time" being. However, I am most likely going to grab a 270 cam from enginebldr on ebay (I think) and an OBX stainless steel header meant for a 82-85ish celica with the 22R. Unless of course, anyone else has any suggestions or cautions...
I got the carburetor base milled out by the local speed shop. If I had access to a mill it would've taken me maybe like an hour MAX to clamp it down and cut. The shop (Don's Performance Corner - Harrisburg, PA) charged me $60 plus tax. Talk about b.s. - I've known the owner for a number of years and I half expected him to do it for free. Let's just say that business relationship is over.
Got some more polishing done and definitely going to work on the separation wedge at the base of the carb, inside the intake manifold. I'll get some pictures of the milled carb base and the piece I am planning to insert into the bottom of the manifold. I'll put some pictures up by Sunday I suppose.
Old 10-24-2009, 07:24 PM   #7 (permalink)
Mad Scientist
Originally Posted by JoeDirtMcD3 View Post
are you going to turn this into the wedge to increase the airflow? that part just looks like it would hinder performance....like a wall.
Camry Wagon Crew
Old 10-24-2009, 09:21 PM   #8 (permalink)
No, I have since removed that small separation section to make the opening look ovaled and not interfere with the fuel mixture's path. It now looks as follows:
and the wedge im talking about will fit down into the manifold and look something like this:
It's purpose will be to help direct the mixture to the front and rear cylinders with less of an abrupt angle.
Old 12-01-2009, 07:46 PM   #9 (permalink)
Hello to those of you who read this and my apologies. This swap business has taken extremely too long for several reasons. The original automatic transmission in my Corona broke (something internally) and the car has been down for awhile, about one month so far I think.
I used this opportunity to convince the owner (my dad) to allow me to swap a w58 trans from a supra in. He agreed and this project was put on hold while I found a suitable transmission for the swap. I located a used w58 pulled from an 87 supra that got a 1jz swap, so it should be in decent shape. I got it and the driveshaft for $180 over in NY. I'm just about done obtaining the remaining parts for that swap, I only need clutch and brake pedals and clutch fork. I'll probably also buy new clutch master and slave cylinders while I'm at it.
The other bonus about having the car down is now I can repaint the engine and clean the engine bay! HOORAY! Seriously though, I just put a beautifully cleaned 22R in last winter only to have the front oil pump seal (around the crank pulley) leak oil and fling it all over the clean engine bay. The mechanically driven cooling fan helped to disperse that oil everywhere. I also had oil leaking from somewhere, either the valve cover or underneath the front of the cylinder head, where that bolt is usually hidden in the pool of oil... well, that bolt was not there upon disassembly.
So I tore the whole engine down. I'm attempting to go for no leaks again, yet I haven't once achieved it first try. While it is apart I decided to replace the cheap plastic timing chain guides with metal backed ones meant for the dual timing chain. Mine's a single because whoever rebuilt it was probably cutting costs. I also swapped my solid cam sprocket with a different one that has the holes bored in it so there will be less rotating mass. The block is on the engine stand awaiting a good washing, acetone wipedown, and some fresh Dupli-Color Engine paint (Gloss Black) on the block only. The timing cover was covered in oil and the silver paint had stained a yellowish tinge. I cleaned it and the oil pump down and painted them Rustoleum metallic gold. I bought a new water pump and will paint that the same gold color. The pulleys will get a fresh coat of Dupli-Color Silver Wheel Paint, and all the bracketry that is painted blue will be painted gold instead. All the bolt heads also will also be painted either gold or silver to offset whatever color they contact.
Which brings me to finishing the HYBRID swap that I initially stated I would do.... (next post)
Old 12-01-2009, 07:52 PM   #10 (permalink)
I got tired of polishing the manifold and gave up on it for more important things. I had a huge problem trying to find the appropriate thermostat housing so that I could maintain a mechanical fuel pump. The two water outlets I had both pointed directly at the mechanical fuel pump and would not have allowed any room to connect the upper radiator hose. I took a guess and ordered a thermostat housing or water outlet as they can be called for a 1980 toyota pickup with the 20R. This piece is the proper one, however it is cast iron unfortunately.... So much for lightweight cast aluminum... or polished aluminum for that matter. So I painted the cast iron piece I got and decided to do a pre-assembly of stuff I have so far. Oh, one more thing - I also tapped the EGR ports / outlets on the exhaust side of the head for 1/8" NPT plugs that I will install with a bit of exhaust cement prior to installing the head.
Here are the pictures of pre-assembly
I'm getting closer finally!
Old 12-01-2009, 09:31 PM   #11 (permalink)
DeBadged
Raffaelli's Avatar
Bahahah! I did the exact same thing. Started polishing the intake, and realized that its a huge pain in the rear.
Your build is exactly like mine! Makes me wonder which would be faster. A Corona or Pickup. Guess it would come down to gearing...
I welded a bolt into the EGR passage on the exhaust manifold, I didnt have the tool to tap em. Mickey Mouse, but it worked.
What size weber is that? Any porting gunna happen? ( On a complete sidetrack, I saw a Dual weber 45 intake with carbs 20R head at Autorama this weekend for 500. I got soo hurt I im broke...)
RN 44 Magnum
Old 12-02-2009, 09:08 PM   #12 (permalink)
Yea dude it is just like yours... IT BETTER BE AS GOOD AS YOU PROMISED!!! It's a Weber 32/36 with electric choke. I don't think I'm going to port anything now... I'll see how it is without that first. Do you have a header? I cant wait to drive it...
Old 12-03-2009, 09:02 PM   #13 (permalink)
DeBadged
Raffaelli's Avatar
Promised?! Bah!
Dont worry bud, it will run good. I dont have a header, but I do have a cat-less 2.5 inch hi flow exhaust. A plugged cat can ruin lots of power...
Did I say upgrade the bottom end? Like arp rod bolts and balance. 3.5inch stroke isnt reall revvy and peppy, but its real grunt.
Rod bolts cant be more than 60. 200 for a balance. I dont trust a factory bottom end for real RPMs. After all I blew up a K20 Acura overrevving(supposidly impossible)
5,500 is all I push it. 6K once on accedent. Need pics of the car! All I can imagine is a poop brown 4 door. Know the diff ratio?
B4 I forget. You need a W series bellhousing that came off a 22r/re. The I6 supra bellhousing doesnt work. 2 or 4wd pickup would work.
RN 44 Magnum
Old 12-04-2009, 09:49 AM   #14 (permalink)
Haha it is pretty much a poop brown 4 door. The stock rear end is a 4.30:1 R&P according to the BUILD PLATE and it is the original drum brake rear axle. I recently purchased an AE86 Corolla GTS rear end and I'm not sure of its axle ratio but I can swap ring and pinions I think. The GTS rear has disc brakes and I should be able to find a decent LSD diff for it.
Oh and I know about the bellhousing, I have one already. Except I don't have the right clutch fork so I'm not sure what I'm going to do about that: either cut up the supra fork and modify it or buy the proper one from somebody on ebay.
I'm not building up the bottom end because of budget, but if I blow one more 22R bottom end I'm definitely building one up myself with forged and brand name components. Yeah, I won't be revving over 6k if I can help it, plus if I need to go high revs I will probly get a nissan sr20det.
Here's a picture:
Old 12-04-2009, 03:46 PM   #15 (permalink)
DeBadged
Raffaelli's Avatar
If you got the 4.30 R&P, Id say leave it. It would get and go proper. IIRC those corollas had real wussy discs on em...
Id second getting a lsd of some sort. Mines a tire fryer and Im working on that.
Nice car by the way.
Do you have a hydralic clutch master/pedal assembly? If you do, just get a hydralic slave, fork, and clutch kit out of a pickup. The lines are just regular flared brake hose.
RN 44 Magnum
