Corona Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Corona Forum Specific discussion of the Toyota Corona
Old 10-19-2011, 01:08 AM   #1 (permalink)
View aussiecorona's Photo Gallery
Corona Problems
Hey all,
Long time forum lurker, but a tricky problem with my Corona has got me on here to ask for some help.
I've a 1991 imported (from Japan) Corona sedan, with a 3S-FE engine.
It runs fine 90% of the time but at completely random intervals will lose power and the engine will cut out. After waiting 30seconds - 20min I can restart it and it will keep going as per normal for the next day or two.
I've tried -
- the diagnostics trick, but have no error codes coming up.
- changed the fuel filter (first thought)
- Drained and replaced the fuel (possibly bad fuel)
- I've put a voltmeter on the MAP sensor, and with the ignition on but engine off it was showing 4volts (I believe it should show 5volts?) and at idle it will sit around 1.6volts.
Now my limited mechanical knowledge is exhausted, and my only remaining fix is to change the MAP sensor over.
Question #1
Do you guys know of any other reasons for intermittent complete loss of power.
Q#2
Do you guys know if the MAP sensor is interchangeable with Camry or Corolla models of the same era?
Thanks guys,
hopefully my luxury car will last another 20 years!
aussiecorona is offline   Reply With Quote
Old 10-26-2011, 09:20 AM   #2 (permalink)
Old cars are my destiny
79Corona's Avatar
View 79Corona's Photo Gallery
Wish I could help, Coronas ended in the USA in 1982.
Bryan
86 Hilux LE longbed
Other Toyotas : 79 Corona DLX sedan (Mint green), 89 Corolla DX sedan (wine), 88 Camry V6 LE sedan (blk), 86 Hilux std bed (wine), 82 Celica GT hatchback (bwn), 78 Celica GT coupe (slvr), 76 Corolla SR-5 coupe (wht)
79Corona is offline   Reply With Quote
