1980 Corona - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corona Forum
Corona Forum Specific discussion of the Toyota Corona
Old 10-23-2011, 09:35 AM   #1 (permalink)
View oldcarnut's Photo Gallery
1980 Corona
Hi can anyone tell me what the tube going into the catalytic converter on my 1980 corona is for and can i bypass it
oldcarnut is offline   Reply With Quote
Old 10-23-2011, 05:29 PM   #2 (permalink)
View Stefman454's Photo Gallery
that will be the catalytic converter supply pipe, coming from the air pump which is all part of the environmental control system and prevents backfiring
Sent from my Autoguide iPhone app
Stefman454 is offline   Reply With Quote
Old 10-26-2011, 08:50 AM   #3 (permalink)
Old cars are my destiny
79Corona's Avatar
View 79Corona's Photo Gallery
Mine was totally rusted out as was the catalyic converter. I replaced the converter with a new one, and gutted the airpump system. I gutted the air pump and it remained only as an idler pulley for my A/C compressor.
Bryan
86 Hilux LE longbed
Other Toyotas : 79 Corona DLX sedan (Mint green), 89 Corolla DX sedan (wine), 88 Camry V6 LE sedan (blk), 86 Hilux std bed (wine), 82 Celica GT hatchback (bwn), 78 Celica GT coupe (slvr), 76 Corolla SR-5 coupe (wht)
79Corona is offline   Reply With Quote
Old 10-30-2011, 08:24 PM   #4 (permalink)
Did you have any complications with removing that system?
Old 10-31-2011, 12:04 PM   #5 (permalink)
79Corona's Avatar
No, none that I ever noticed. I put a Weber carb on it too.
Bryan
86 Hilux LE longbed
Old 10-31-2011, 03:43 PM   #6 (permalink)
Is yours a 4M? If so, which carb did you use? I'm thinking of changing mine too
Old 11-01-2011, 08:35 AM   #7 (permalink)
79Corona's Avatar
No, Coronas didn't come with a 6 cyl, mine has a 20R with a Weber carb I installed.
Bryan
86 Hilux LE longbed
Old 01-20-2012, 06:48 PM   #8 (permalink)
View bwjunkie's Photo Gallery
air pump
re: 20r '80 corona dlx.
When I installed a Weber carb I left the air pump hose hanging, later the air pump bearings went bad, so I just took the belt off, since I have no A/C.
I still haven't handled the upper loose hose. I want to completely remove the pump, but I don't know how to handle the lower hose, maybe just plug it?
-josh
bwjunkie is offline   Reply With Quote
Old 01-23-2012, 02:56 PM   #9 (permalink)
View phillipsjo's Photo Gallery
1977 Toyota Corona
I have a 4 door Corona 1977 with 20R engine that is in need of a tri-y header. What would fit as some are saying that 20R Corona will not work with a Thorley header for Toyota pick up.
Thank you
phillipsjo is offline   Reply With Quote
Old 01-25-2012, 10:58 AM   #10 (permalink)
79Corona's Avatar
I'm not familiar with headers for the 20R engine. What do you mean by a tri-Y header?
Bryan
86 Hilux LE longbed
Old 01-25-2012, 12:18 PM   #11 (permalink)
79Corona's Avatar
-josh
I had A/C, so I gutted the air pump (vanes already broken) and made it the idler pulley for the A/C belt. I would cap off any leftover end that will affect the engine.
Bryan
86 Hilux LE longbed
Old 03-03-2012, 08:23 AM   #12 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $592955
View fourwd1's Photo Gallery
A tri-Y header design has tubes from cyl 1 and cyl 2 connecting together creating one Y. Output of cyl 3 and cyl 4 creates a second Y. Those 2 outputs run together to create a single output, the third Y.
Y Y
.Y
Another header design would be the 4-into-one.
One is better at lower rpms, the other produces more power at higher rpms.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
