Brake bleeding help
I completely redone the brake system , rebuilt caliper kits,new rear wheel cylinders lines,etc.
While starting from the farthest point Driver rear i didnt get any fluild back to the brakes,,the resivoir remained full,,so i started from the front and the front D and P side are done...Do i need to prime the master brake cylinder?? i saw a bleed valve (i believe) on the side of it.I tried a couple sites on bleeding the system but nothing helped..So in other words i cant bleed the rear brakes but the front is done. Can someone help me on the correct procedure...Thanks
1973 corona 2 D hardtop, automatic, 18RC
