Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Clear 93 Tercel headlights
View Single Post
Old 06-08-2006, 02:41 AM   #7 (permalink)
CamryOwner98
Home of the Demon Cam
CamryOwner98's Avatar
View CamryOwner98's Photo Gallery
Originally Posted by Tercel GTS
Could use the glass to make a template for molding lexan....
Molding Lexan? Hmm... I'm not firmilar with that at all. But I have played with that idea before.
Originally Posted by ice_d_mugg
clear like this? im going to get an HID system for mine soon, thats the whole reason i wanted these headlights, because the stock 93 composite lamps just arent good for HID
Are you putting projectors in there? Just a kit would cause massive glare.
Originally Posted by iruka_hoshi
Is that how come you went to so much trouble fabing those sentra lights up? I am planning to swap in the DX lights, you don't think those will work well for HID conversion. I've been thing about HID, I am little unclear if you lose high beams or not.
DX lights are textured, right? Either way, there will be glare, unless the housing was designed to accept HID bulbs. Cars that have HID headlights without the use projectors use a variation of the bulb called D2R, which has a painted shield on the bulb itself to reduce glare.
Also oem HID kits don't have high beam function like H4 bulbs, unless you get those aftermaket (ricer) kits.
Mods:
HID TL Bi-Xenon Projectors~Auxillary Bosch Mini Projectors~
Superflux LED Tails~
Euro guages~Halogen Fogs~
CamryOwner98 is offline   Reply With Quote
