Re: Now, onto the alarm
"Hachiroku" <Trueno@ae86.GTS> wrote in message
news:Tnrig.732$ZB3.700@trndny05...[color=blue]
> On Sun, 04 Jun 2006 18:06:44 -0500, Ray O wrote:
>[color=green]
>> news:juFgg.588$qo4.463@trndny05...[color=darkred]
>>>> news:tbjfg.42$_F6.38@trndny03...
>>>>><snipped>
>>>>> Oh, hay, I got a question for you.
>>>>> I chased the wire from the Driver's door back to the Fuse block,
>>>>> tapped
>>>>> into it, and the alarm works Just Fine...
>>>>> from the Driver's door.
>>>>> I am assuming there is some function from the Driver's door grounding
>>>>> switch that is NOT activated by the passenger's door.
>>>>> On all my other Toyotas, I have followed this wire back to the fuse
>>>>> block,
>>>>> tapped into it and had no problem. On one car it even activated when
>>>>> the
>>>>> hatch was opened.
>>>>> So, I need to find a grounding connection common to both doors;
>>>>> possibly
>>>>> the dome light.
>>>> I would use the dome light circuit because it does both doors and I
>>>> think
>>>> it
>>>> also does the hatch.
>>> I was looking for it! Any idea where it might be? Or, what color wire am
>>> I
>>> looking for?
>>> The paper I dl'd from the internet gave the colors for the doors, but
>>> for
>>> "Dome Light Supervision", it said "none"
>>>[/color]
>> Sorry, off the top of my head, I have not idea what color or where the
>> dome
>> light wires might be. you can pull the dome light assembly to see what
>> color the wires are, and then look at the bottom of the driver's side
>> A-pillar and see if you can find it.[/color]
> When I did my Corolla I used an ohm/volt meter, but that method didn't
> work this time!
> If it ever STOPS RAINING here, I'll give it a go![/color]
You need to get one of those awnings with aluminum pole frames that you can
park a car or boat under. I think they are around $300 at Sam's
Club/BJ's/Costco. As long as there is no lighting in the area, they are
pretty slick.
I know some Boy Scout troops that use those when they go camping, although
our troop uses traditional canvas dining flies with wooden poles, guy lines,
and stakes.
Ray O
