AE92 4dr to GTS specs - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 03-24-2006, 06:55 PM   #16 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
88 and 89 were carb (not sure if EFI was an option) 90-92 were EFI.
The 4afe tank and lines would be fine for a 4age. The tranny would be fine (C50 I believe). The ECU has to be changed. The harness has to be changed.
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 03-24-2006, 07:01 PM   #17 (permalink)
View aznramen's Photo Gallery
Canada
Is it true that 1990 4dr Corollas in Canada used the 4a-fe? If so, then would a 4dr be a good candidate for the 4a-ge swap? Of course there would be added strut bars and sway bars to prevent as much warping as possible. And also all the aforementioned modifications in response to my previous question.
Thanks in advance.
Ramen (not my real name silly...)
aznramen is offline   Reply With Quote
Old 03-25-2006, 12:22 AM   #18 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $272821
View REN69's Photo Gallery
yes 4dr and SR5s used the 4AFE, btw in Japan 4dr sedans came with 4AGEs
suspension wise, the 4dr should be able to take the 4AGE, I mean its not like you're swapping a 4AGZE or 3SGTE where the suspension would have to be upgraded in order to make up for the extra hp and torque, so even if you don't upgrade sway bars, you could at least upgrade struts, springs and I would suggest to put the strut bar in, and you should be ok.
REN69 is online now   Reply With Quote
Old 08-02-2006, 09:38 PM   #19 (permalink)
Gameroom cash: $100900
View 4doorGTS's Photo Gallery
Canada
Yes all parts from an ae92 gts will fit onto an ae92 sedan. Motor, trans, seats, steering wheel, suspension, fuel pump and mayby even the entire front clip. I was going to try that myself but the front would look too long compared to the shorter rear of the sedan. Im almost done my swap and will make a thread about it soon. Untill then.....
and yes its going in for bodywork this coming winter
4doorGTS is offline   Reply With Quote
Old 08-02-2006, 10:57 PM   #20 (permalink)
get sideways
View coco4pr3z's Photo Gallery
bump for junkyard runs!!!!
coco4pr3z is offline   Reply With Quote
Old 08-03-2006, 07:02 PM   #21 (permalink)
20v 4dr AE92
View Corolla101's Photo Gallery
alright im interested in doing the swap
i went down to the junkyard earlier and picked up the strut bar, as far as the front suspension conversion goes, what will i need from the SR5 to be able to fit the front sway bar in? And the rear has the same setup correct?
Corolla101 is offline   Reply With Quote
Old 09-19-2007, 07:21 AM   #22 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
just get whiteline sway bars they are worth the extra money, there brand new and the best you can get.
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
jmaz87 is offline   Reply With Quote
Alot of stuff for sale 2advanced Car Parts for Sale 41 05-02-2007 12:36 AM
AE86 GTS to SR5 same as AE92 GTS to SR5 Conversion? OwnerOfReality Archived Corolla threads 34 08-02-2006 04:37 AM
AE92 GTS Common Problems Xenon Archived Corolla threads 8 06-01-2003 12:51 PM
Proud new owner of a 1988 AE92 GTS karma Archived Corolla threads 16 07-30-2002 06:14 PM
