AE92 4dr to GTS specs - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 03-21-2006, 06:22 PM   #1 (permalink)
View aznramen's Photo Gallery
AE92 AE92 4dr to GTS specs
It just came across my mind after looking at some AutoTrader listings, but how hard would it be to get a 4dr version up to specs with the gts using aftermarket parts instead of Toyota stock parts? Of course the engine (4afe) would need to be changed to a 4age EFI, but would everything else match up fine?
_________________
When in doubt grab some tofu...
...And maybe some ramen....
aznramen is offline   Reply With Quote
Old 03-21-2006, 07:09 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Yep.. you would need OEM parts from the GTS actually, mostly the strut bar (would need to drill firewall), front sway bars, rear sway bars, front serviceable struts (rears are the same).
As for motor, you could go with either Bigport or smallport 16V 4AGEs or go to a 20V 4AGE or even a Supercharged 4AGZE , you would need the full Engine, transmission, manifolds, ECU, harness, AFM (unless its a MAP sensored motor), and most likely upgrade your fuel pump (even if the sedan FP works, I'd upgrade anyways) and probably the drum brake to disc brake conversion on the rear.
This is something I actually have considered as I wanted to do the same from a GTS to a sedan, but I'm looking at other possibilities with my 89 GTS.
Old 03-22-2006, 11:25 AM   #3 (permalink)
View micro214_kp61's Photo Gallery
AE92 SPRINTER 4dr.
1982 Toyota Starlet (SP61) boosted since 2007
micro214_kp61 is offline   Reply With Quote
Old 03-22-2006, 02:08 PM   #4 (permalink)
View lex_addict's Photo Gallery
^ ae92 4door with spinter face pwnz
1992 ls400
1987 corolla gt-s [coupe]
lex_addict is offline   Reply With Quote
Old 03-22-2006, 06:36 PM   #5 (permalink)
KDM is in
REN69's Avatar
I like this Sprinter front end too...
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 03-23-2006, 03:56 AM   #6 (permalink)
Exhaust Time!
91_CorollaWagon's Avatar
View 91_CorollaWagon's Photo Gallery
hmm....looks like ill be making a few calls to my toyota dealer tomorrow!
John
91_CorollaWagon is offline   Reply With Quote
Old 03-23-2006, 07:57 AM   #7 (permalink)
John
hehehe.. godluck with that!
Old 03-23-2006, 03:02 PM   #8 (permalink)
Exhaust Time!
huh?
John
Old 03-23-2006, 07:27 PM   #9 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Seems like most everything AE92 is no longer available at the dealer.
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
89 MR2 SC - 314k! rims, cams, lsd, pulley, exhaust, intake, header, brakes, stereo, bushings... still going!
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, Edelbrock struts, lots of audio
aaron7 is offline   Reply With Quote
Old 03-23-2006, 08:05 PM   #10 (permalink)
Exhaust Time!
Just got off the phone with my toyota dealer...
GTS Sways front and rear 97.63 from the factory..per bar
And... the strut tower brace....THEY DO NOT HAVE IT! had to call the warehouse, and now he's gonna call japan to see if they can special order it from japan.....he said they no longer have it on file nor is it in thier stock....I sugessted that it was a TRD piece, and when he checked, even TRD is not showing up on his computer....still awaiting his call.
John
Old 03-23-2006, 08:14 PM   #11 (permalink)
omg jdm
aaron7's Avatar
Get one on ebay. They sell for about $30.
Old 03-23-2006, 08:45 PM   #12 (permalink)
Exhaust Time!
well...sorry to say, but Toyota no longer makes the Strut brace for the GTS...discontinued....better off making one by yourself or look for one on ebay.
John
Old 03-24-2006, 09:31 AM   #13 (permalink)
^now you know why i said... goodluck! hehehe
Old 03-24-2006, 04:41 PM   #14 (permalink)
Mr. Nice Guy
canadianae92's Avatar
View canadianae92's Photo Gallery
Just get one from the junkyard jeez, and to make it stiffer weld a bar across betwee nthe two srut or whatever locations like straight across i mean(not onto the car of course) and stiffen it up with some welding.....
canadianae92 is offline   Reply With Quote
Old 03-24-2006, 07:44 PM   #15 (permalink)
Do any of you guys know if the Ontario/Canada versions of the SR5 came with the 4A-F or 4A-FE? In the case of the 4A-FE swapping in a 4A-GE, would the gas tank, ecu + harness, transmission, or fuel pump need to be swapped as well to suit the 4A-GE?
When in doubt grab some ramen!
Alot of stuff for sale 2advanced Car Parts for Sale 41 05-02-2007 01:36 AM
AE86 GTS to SR5 same as AE92 GTS to SR5 Conversion? OwnerOfReality Archived Corolla threads 34 08-02-2006 05:37 AM
AE92 GTS Common Problems Xenon Archived Corolla threads 8 06-01-2003 01:51 PM
Proud new owner of a 1988 AE92 GTS karma Archived Corolla threads 16 07-30-2002 07:14 PM
