Won't start, 1986 ae82 4alc - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 04-23-2006, 01:50 AM   #1 (permalink)
View hammy211's Photo Gallery
My car is turning over fine, but does not fire whatsoever. Even with starting fluid there is no effect. Since the starting fluid doesn't help I'm assuming it isnot a fuel problem. I put a new filter in anyway. I replaced the fuel pump about 5k ago. I had new plugs and wires, so I went ahead and installed them. Rotor looked pretty bad to me so I put a new one on and cleaned up the points. Still wouldn't start. I haven't checked the timing, but it was running fine before this except for a flat spot in the carb. I also have not checked for spark. I will do that on Monday. If I find I do have spark where do I go from there? If not? Sorry for the newbie questions. I've done alright with this car so far, but unsure where to start with this problem.
1986 Corolla 4ALC
hammy211 is offline   Reply With Quote
Old 01-25-2008, 06:25 PM   #2 (permalink)
View openflame06's Photo Gallery
check for spark, no spark maybe the coil is gone. If there is maybe its starving for fuel so its not actually burning anything
openflame06 is offline   Reply With Quote
'85 rolla no start powerslide713 Older Generations (1969-1987) 10 04-08-2008 11:07 PM
2001 Tacoma won't start HotRodd38 1st Generation (1995.5–2004) 6 11-12-2007 04:44 PM
Engine won't start camree99 Camry & Solara Lounge 1 01-27-2006 07:41 PM
Click sound from under the hood..won't start snobdrblinkchik Camry & Solara Lounge 10 08-22-2004 10:04 PM
Need help asap. No start problem. kieran1094 Archived Corolla threads 2 07-28-2002 11:48 PM
