AE92 sedan suspension upgrades - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 05-05-2007, 04:15 PM   #16 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I was taking a look at the sr5 front shock and spring, and the sr5 ones I have... I couldn't really find a difference. They look the same to the eye, like for the casing and such. The spring is thicker on the gts one, but next time I get ahold of a spring compressor I will take them apart and see. Was going to when I swapped out my spring but meh.
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 05-05-2007, 08:00 PM   #17 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $272821
View REN69's Photo Gallery
I agree with Flashmn on the sway bars, they should fit.
As for suspension, go with Ksport coilovers, after driving Minesh's car I was surprised as to how well they handled.. btw his car was about 1inch lower than my car and I'm already at a 1.8inch drop.
REN69 is online now   Reply With Quote
Old 05-06-2007, 03:52 PM   #18 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
AARON420.
You will probably need to replace your rear shocks since that is where the ends of the sway bar attaches. The original shocks on cars that were sold without sway bars didn't have the attach ears/brackets on them, but the aftermarket shocks that I have seen (KYB & Monroe) have the necessary attach points. From the photo, you are also missing the "dog bone" links for the back. I think I have an extra set of those in useable condition, if you need them I'll give them to you.
I am not sure, but on the front, I think you will need to swap the lower control arms, to get those attach points.
You might be able to fabricate some ears/brackets for the front, but on the back they are welded directly to the shock tube.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 07-18-2007, 03:25 PM   #19 (permalink)
View djace7777's Photo Gallery
I have seen some guys running the tein springs on there ae-92 how is this possible what year car are they getting them from ??????
djace7777 is offline   Reply With Quote
Old 07-18-2007, 05:21 PM   #20 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Probably AE100 series, they fit if you use the whole package.
I have yet to see an AE92 without a rear sway bar.
Old 07-18-2007, 05:42 PM   #21 (permalink)
yea I read that so just ae100 struts springs bolt right up thats cool defintally gives more options
Old 07-18-2007, 06:40 PM   #22 (permalink)
Resident asshole
Flashmn's Avatar
Yeah, they should bolt on.
Old 07-18-2007, 06:47 PM   #23 (permalink)
I may go to the local wrecker and pull of the whole strut and spring assembly for 15$ JSUT TO CHECK put it in just to see for placement but that would work man cool has anyone done it suucesfully
Old 07-25-2007, 10:59 PM   #24 (permalink)
Donald's Avatar
We are not so lucky in the USA. There is a lot of good stuff we don't get.
Old 07-26-2007, 08:32 AM   #25 (permalink)
Gameroom cash: $100900
View 4doorGTS's Photo Gallery
Same up here, we didn't even get threads for the rear sway bar on canadian spec sedans.
4doorGTS is offline   Reply With Quote
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
WTB: Clear front turn signal lenses for ae92 sedan fistofmeat Car parts for trade or wanted parts 1 07-19-2007 06:06 PM
WTB: AE92 Sedan Cluster w/ Tach fistofmeat Car parts for trade or wanted parts 0 11-13-2006 12:55 AM
ae92 coupe parts in a sedan fistofmeat Archived Corolla threads 2 09-03-2006 10:24 AM
ae92 wagon: suspension replacement options ped Archived Corolla threads 9 06-11-2004 08:52 PM
