[quote=bigtrucknwheels]My manual for my A.E. 86 4A-C auto states that the maximum speed for 1st is 37 MPH and 62 For 2nd. Im sure it shifts sooner if you just put it in drive. Shift the auto by itself.
quote]
that
is with it just in drive, not manually shifting anything. if i slowly accelerate it will shift sooner, if i put the pedal down it shifts quite a bit later.
"Paradise Racing also has the Paradise Racing Power Pack for the Toyota 4AC and Toyota 2/3TC engines!!! It includes a Weber 32/36 Carb Kit, Schneider Cam & Dual Valve Springs. It will provide a
Dyno Proven 40hp and an improved power band up to 8,000 rpms!!!"
$650
it sounds like a good way to up your power.
I've been thinking about it and I don't know if this car is worth working on. there isn't a whole lot of rust all over the car, but a few sections have rusted out quite a bit. and there's some starting to form around where the rear struts are on the inside of the cabin.
I'd love to work on a sedan AE82, but this one would require way too much body reworking...
