AE92 Battery relocation - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 07-06-2007, 07:13 PM   #1 (permalink)
Project92's Avatar
View Project92's Photo Gallery
AE92 AE92 Battery relocation
has anyone done it? How did u do it?
which parts did you use, and how long did it take? =]
My 1991 AE92 GTS
http://www.cardomain.com/ride/2311724
Project92 is offline   Reply With Quote
Old 07-07-2007, 12:15 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $404850
View eage8's Photo Gallery
I've done it in my RX-7, which is a little easier because I put it in a bin behind the passanger seat.
but basically all you need is:
- a battery box secured to your trunk
- short negative ground cable grouding to the body
- long positive cable going to the main fuse box and the starter
- some sort of vent or something if you're going to put a normal battery in it (or you could just put an optima battery or something in that doesn't need one)
- an inline circuit breaker about a foot away from the positive battery terminal (like 150A most car stereo places have them)
I think that might be it... I might be forgetting something though.
it took me a while because I was doing crap loads of other work on the car at the same time. you could probably do it in like 2 hours though if you have all the right parts.
make sure the wires are thick enough too, I think I used like 2 guage.
if you look on summitracing.com they have kits that have the box and the wires for fairly cheap, or you could just get a marine battery box from walmart for like $10 and get the wires from a car stereo place.
let me know if I left anything out :-P
'81 BMW R65
Old 08-02-2007, 09:23 AM   #3 (permalink)
View Sebas007's Photo Gallery
I don't know if it can help...but I want to be help
Here my DIY thread on SG
http://www.solaraguy.org/viewtopic.php?t=34705
I still got hesitation problem when I keep reving on the same gear example 70PHM in 3rd gear. Some say I've bad grounding connection....I think it could be more induction from my positive wire passing near other wire and sensor in the kick panel (near the left foot driver side).
What are you opinion on it ???
Sebas007 is offline   Reply With Quote
Old 08-02-2007, 10:03 AM   #4 (permalink)
Rotary guy...
eage8's Avatar
nice DIY thread.
one thing I've heard is that some cars the ground signal doesn't pass through the body very well, so I have a ground going from the body ground to my transmission/starter where it was grounded before.
the ground you took off has 2 grounding points, so find out where the other one was, and at least ground that to the body if you don't want to run another cable all the way to the trunk.
I would also advise getting a circuit breaker near the batter just in case something bad happens to the really long + battery cable.
other than that it looks good. :-)
'81 BMW R65
Old 08-02-2007, 10:30 AM   #5 (permalink)
Thanks man !!
I was afraid to have to do it...passing the negative cable where it was plugged before.
No more space in my positive route (I think).
Old 08-02-2007, 10:44 AM   #6 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Good Job
Beautiful DIY....I'm glad to see the SWITCH everyone was talking about that HELPS ALOT!!!!
FinalGear is offline   Reply With Quote
Old 08-02-2007, 11:09 AM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
4gauge power wire and a marine battery box in the trunk, that's how one of the AE92 guys (Xenon) did it.
Old 08-02-2007, 11:35 AM   #8 (permalink)
My relocation is already made....
I have 18' 1-gauge positive wire routed thru the firewall
I have 1.5' 1-gauge ground wire routed on the frame...
seems like my frame is not enough conductor.....
Dead Battery After 1 Year Mikey D Archived Corolla threads 10 04-09-2007 04:36 AM
Battery or battery terminals shoes1382006 89-95 Toyota Pickup/Hilux 9 12-18-2006 11:44 PM
Battery Problems haux Camry & Solara Lounge 3 09-21-2006 01:48 AM
Dead battery OR something else... AutoBox Camry & Solara Lounge 3 07-12-2006 08:39 PM
Alternator battery something else kewl1284 Tercel, Paseo, Starlet, and Sera Forum 13 07-05-2006 10:53 AM
