TRD parts question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 07-13-2007, 02:11 AM   #1 (permalink)
HatchBackKid's Avatar
View HatchBackKid's Photo Gallery
AE86 TRD parts question
I was just wondering if there is a good place to find trd parts for the ae86.
HatchBackKid is offline   Reply With Quote
Old 07-14-2007, 09:25 AM   #2 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
This is all the trd parts i have listed
C0TRA-17500-01
00602-17500-001 Muffler, 1998-2002 430.00 $ 537.00 $
C0TRA-17500-01
00602-17500-001 Silencieux, 1998-2002 430.00 $ 537.00 $
C0TRA-17500-16
00602-17500-016 Muffler,Sport,Corolla 2003-2004 610.00 $ 760.00 $
C0TRA-17500-16
00602-17500-016 Silencieux, 2003 610.00 $ 760.00 $
C0TRA-17500-17
00602-17500-017 Muffler,Sport,Corolla XRS 2005 620.00 $ 780.00 $
C0TRA-17500-17
00602-17500-017 Silencieux, XRS, 2005 620.00 $ 780.00 $
C0TRB-17621-07
00602-17620-107 Supercharger Installation Kit , ATM,2003 1,450.00 $ 1,800.00 $
C0TRB-17621-07
00602-17620-107 Trousse d'installation de suralimenteur, automatique, 2003 1,450.00 $ 1,800.00 $
C0TRB-17621-08
00602-17620-108 Supercharger Installation Kit , MTM, ,2003 1,450.00 $ 1,800.00 $
C0TRB-17621-08
00602-17620-108 Trousse d'installation de suralimenteur, manuelle, 2003 1,450.00 $ 1,800.00 $
C0TRB-17621-14
00602-17620-114 Supercharger Installation Kit , ATM, 2004 1,450.00 $ 1,800.00 $
C0TRB-17621-14
00602-17620-114 Trousse d'installation de suralimenteur, automatique, 2004 1,450.00 $ 1,800.00 $
C0TRB-17621-15
00602-17620-115 Supercharger Installation Kit , MTM, 2004 1,450.00 $ 1,800.00 $
C0TRB-17621-15
00602-17620-115 Trousse d'installation de suralimenteur, manuelle, 2004 1,450.00 $ 1,800.00 $
C0TRB-17621-20
00602-17620-120 Supercharger Main Assembly , 2003-2004 2,400.00 $ 3,000.00 $
C0TRB-17621-20
C0TRA-17620-16
00602-17620-166 Carbon Fiber Engine Cover , Base, Sport 2003 - current 135.00 $ 170.00 $
C0TRA-17620-16
00602-17620-166 Couvercle de moteur en fibre de carbone, modèles de base et XR 2003- 135.00 $ 170.00 $
C0TRA-17801-10
00602-17801-010 Air Filer, 2003-2005 ,all models 74.00 $ 98.00 $
C0TRA-17801-10
00602-17801-010 Filtre à air, 2003-2005 ,tous les modèles . 74.00 $ 98.00 $
C0TRA-17802-02
00602-17802-002 Cold Air Intake, CE, LE ( does not fit Corolla S) 2003-2004 345.00 $ 430.00 $
C0TRA-17802-02
00602-17802-002 Prise d'air frais, modèle ,CE,LE 2003-2004 345.00 $ 430.00 $
C0TRA-30301-02
00602-30301-002 Quickshifter, GTS 1985-1987 280.00 $ 350.00 $
C0TRA-30301-02
00602-30301-002 Trousse de levier rapide, GTS 1985-1987 280.00 $ 350.00 $
C0TRA-30301-05
00602-30301-005 Quickshifter,AE92,GTS/SR5 170.00 $ 215.00 $
C0TRA-30301-05
00602-30301-005 Trousse de levier rapide, GTS, SR5 1988-1991 170.00 $ 215.00 $
C0TRA-30301-08
00602-30301-008 Quickshifter, 1998-2002 175.00 $ 220.00 $
C0TRA-30301-08
00602-30301-008 Trousse de levier rapide, 1998-2002 175.00 $ 220.00 $
C0TRA-42600-30
00602-42600-301 Wheel /Lock/Lug Set, 18" , all models ,2003-2005 2,450.00 $ 3,000.00 $
C0TRA-42600-30
00602-42600-301 Ensemble roues/pneus, 18 po, tous les modèles .2003-2005 2450.00 $ 3000.00 $
C0TRA-42601-CR
00602-42601-COR Lock/Lug Set,(For 16" wheel), 1998-2002 125.00 $ 165.00 $
C0TRA-42601-CR
00602-42601-COR Ens. roues/verrous/écrous, 1998-2002 125.00 $ 165.00 $
C0TRA-48130-23
00602-48130-022 Lowering Springs Set, All models, 2003-2005 325.00 $ 400.00 $
C0TRA-48130-23
00602-48130-022 Ens. ressorts courts, tous les modèles,2003-2005 325.00 $ 400.00 $
C0TRA-48130-CR
00602-48130-COR Lowering Spring Set 1998-2002 210.00 $ 265.00 $
C0TRA-48130-CR
00602-48130-COR Ens. ressorts 1998-2002 210.00 $ 265.00 $
C0TRA-48810-01
00602-48810-001 Sway Bar, Front, SR5/GTS 1984-1987 210.00 $ 270.00 $
C0TRA-48810-01
00602-48810-001 Barre stabilisatrice avant, SR5/GTS 1984-1987 210.00 $ 270.00 $
C0TRA-48810-03
00602-48810-003 Sway Bar, Front, SR5/GTS 1988-1991 220.00 $ 280.00 $
C0TRA-48810-03
00602-48810-003 Barre stabilisatrice avant, SR5/GTS 1988-1991 220.00 $ 280.00 $
C0TRA-53607-05
00602-53607-005 Strut Tower Brace, Front ,1998-2000 210.00 $ 260.00 $
C0TRA-53607-05
00602-53607-005 Barre de jambe de force avant Corolla, 1998-2000 210.00 $ 260.00 $
C0TRA-53700-01
00602-53700-001 Strut Tower Brace,Front ( All models except XRS) , 2003-2005 160.00 $ 200.00 $
C0TRA-53700-01
00602-53700-001 Barre de jambe de force avant Corolla, 2003-2005 160.00 $ 200.00 $
C0TRC-17141-12
00642-17141-012 Header, GTS, 4AGE, AE86 (New Design) 1985-1987 398.00 $ 498.00 $
C0TRC-17141-12
00642-17141-012 Tubulure d'échappement, GTS, 4AGE, AE86 1985-1987 (nouveau désign) 398.00 $ 498.00 $
C0TRC-31200-20
00642-31200-020 Clutch, Pressure Plate Assembly, 1986-1992 410.00 $ 515.00 $
C0TRC-31200-20
00642-31200-020 Assemblage de plateau de pression d'embrayage,1986-1992 410.00 $ 515.00 $
C0TRC-48700-05
00642-48700-005 Bushing Set, 1985-1987 329.00 $ 410.00 $
C0TRC-48700-05
00642-48700-005 Ens. coussinets de suspension, 1985-1987 329.00 $ 410.00 $
C0TRC-90915-02
00642-90915-002 Oil Filter ( all Models except XRS) replaces 90915-10001, 90915-03001,
08922-02005
$ 28.10 $ 37.40
C0TRC-90915-02
00642-90915-002 Filtre à huile, (tous les modèles sans XRS)TRD, remplace n° de pièce
90915-10001, 90915-03001, 08922-02005
28.10 $ 37.40 $
C0TRA-90915-06
00602-90915-006 Oil Filter , XRS $ 14.00 $ 18.00
C0TRA-90915-06
00602-90915-006 Filtre à huile, XRS, 2005 14.00 $ 18.00 $
C0TRC-90919-00
00642-90919-000 Spark Plug Wire Set, GTS 1985-1987 125.00 $ 160.00 $
C0TRC-90919-00
00642-90919-000 Ens. fils de bougies, GTS 1985-1987 125.00 $ 160.00 $
C0TRE-11115-00
00643-11115-000 Gasket, Cylinder Head , 4AG, Metal 58.60 $ 78.13 $
C0TRE-11115-00
00643-11115-000 Joint de culasse, 4AG, métallisé 58.60 $ 78.13 $
Corolla
June 2004 / Juni 2004
Liter is offline   Reply With Quote
Old 07-14-2007, 10:29 AM   #3 (permalink)
its a non-prius ha
AzN-BriaN's Avatar
View AzN-BriaN's Photo Gallery
C0TRA-17500-01
C0TRA-17500-01
C0TRA-17500-16
C0TRA-17500-16
C0TRA-17500-17
C0TRA-17500-17
C0TRB-17621-07
C0TRB-17621-07
C0TRB-17621-08
C0TRB-17621-08
C0TRB-17621-14
C0TRB-17621-14
C0TRB-17621-15
C0TRB-17621-15
C0TRB-17621-20
C0TRB-17621-20
C0TRA-17620-16
C0TRA-17620-16
C0TRA-17801-10
C0TRA-17801-10
C0TRA-17802-02
C0TRA-17802-02
C0TRA-30301-02
C0TRA-30301-02
C0TRA-30301-05
C0TRA-30301-05
C0TRA-30301-08
C0TRA-30301-08
C0TRA-42600-30
C0TRA-42600-30
C0TRA-42601-CR
C0TRA-42601-CR
C0TRA-48130-23
C0TRA-48130-23
C0TRA-48130-CR
C0TRA-48130-CR
C0TRA-48810-01
C0TRA-48810-01
C0TRA-48810-03
C0TRA-48810-03
C0TRA-53607-05
C0TRA-53607-05
C0TRA-53700-01
C0TRA-53700-01
C0TRC-17141-12
C0TRC-17141-12
C0TRC-31200-20
C0TRC-31200-20
C0TRC-48700-05
C0TRC-48700-05
C0TRC-90915-02
08922-02005
$ 28.10 $ 37.40
C0TRC-90915-02
28.10 $ 37.40 $
C0TRA-90915-06
C0TRA-90915-06
C0TRC-90919-00
C0TRC-90919-00
C0TRE-11115-00
C0TRE-11115-00
Corolla
i think he wanted to know where lol
AzN-BriaN is offline   Reply With Quote
Old 07-14-2007, 09:33 PM   #4 (permalink)
View Gsolo's Photo Gallery
...umm...toyota is a good place to start
1990 Geo Prizm with Silvertop 20V swap
Toyota Tech
Gsolo is offline   Reply With Quote
Old 07-14-2007, 10:31 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Toyota North America ONLY carries about 5 different TRD parts and that's about it, if you want any TRD parts for the AE86 you'll have to contact a TRD Japan distributor.
TRD USA = Teh suck!
Here's a list of TRD parts for the AE86 that Toyota in Canada can still get for you.. it might take a while but you'll eventually get it.
PTR04-17900-03 - 4A-GE 0.8mm Metal Head Gasket
PTR10-02850-12 - 4A-GE 4-1 Ceramic Coated Header
PTR04-02850-01 - 4A-GE Spark Plug Wires
PTR04-20840-01 - Front Sway Bar
PTR04-20850-02 - Short Shifter
PTR04-00000-05 - Leather 5-speed Shift Knob
PTR04-00000-06 - Ball-type TRD Emblem Shift Knob
PTR14-00000-06 - USA Oil Filter (Taller Style)
PTR04-12108-02 - Oil Filler Cap
PTR04-00000-01 - 18.5psi Radiator Cap
PTR04-00000-02 - 21.3psi Radiator Cap
Old 07-15-2007, 02:37 PM   #6 (permalink)
on full afterburner
PhatRoyale's Avatar
Gameroom cash: $1191747
Toyota dealerships here are terrible at getting TRD parts... all the ones I went to asking to order parts from Japan were like
One even told me all TRD parts were discontinued
Old 07-15-2007, 06:49 PM   #7 (permalink)
KDM is in
REN69's Avatar
They are discontinued, they cannot get anything from Japan hence the reason I said you NEED to find an authorized TRD Japan dealer, only the parts I posted are available through Toyota Canada, sometimes they take weeks to recieve.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 07-15-2007, 07:45 PM   #8 (permalink)
on full afterburner
PhatRoyale's Avatar
Do you know of any dealers around here Ren?
Can you post up or PM me? I've been dying trying to find a local dealer that has access to TRD Japan parts
Old 07-15-2007, 11:46 PM   #9 (permalink)
KDM is in
REN69's Avatar
Not that I know of, I know there's only like 2 or 3 places that distribute TRD parts from TRD Japan but I can't remember the names, Google might help more than me.. OR maybe the TRD Japan site might have a link to their north american distributors.
Old 10-10-2007, 10:18 AM   #10 (permalink)
View CandyXRS's Photo Gallery
THIS PLACE SPECIALIZES IN 2ZZ-GE. www.monkeywrenchracing.com have fun.
CandyXRS is offline   Reply With Quote
Old 10-10-2007, 10:48 PM   #11 (permalink)
KDM is in
REN69's Avatar
LOL!
TRD Paseo Parts Kevpalf Tercel, Paseo, Starlet, and Sera Forum 3 01-03-2006 10:54 AM
TRD parts Abyss MR2 Forum 4 08-30-2005 12:38 PM
matrix TRD wheels question SGG 1st Generation (2003-2008) 2 04-27-2003 07:48 PM
