High Idle Problem Remains...
Well, the 02 Corolla went to the shop on Thursday for the high idle problem that I bought it with. The shop said it was the idle air control solenoid, and replaced it. When I drove home, the idle was still high.
So far, the throttle body has been cleaned, so has the PCV. And, of course, the IAC solenoid. Still have the high idle, still no check engine light.
The idle is low when cold, high when hot (~1500 rpm). It's obviously a computer-related issue because when the engine is revved, it will come down to normal idle for a second then speed itself back up to around ~1500 rpm.
What else could it be????
I called the shop and its going back in on Monday. They still believe it is a IAC solenoid problem, because that is what showed up on the scan tool. I figured that would throw a check engine light, but it didn't.
