91 sedan headlight assembly help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 07-29-2007, 10:02 PM   #1 (permalink)
View raracah's Photo Gallery
Question 91 sedan headlight assembly help
Hi everyone,
Recently I bought a 1991 Corolla sedan for my 17-year old to drive. Both headlight assemblys are loose because of broken plastic pieces where they mount. I'm trying to remove the whole assembly, but can't get to the bottom screw/bolt. Is there a step by step process to remove this thing? Is it one of those "you have to take off this part to get to that screw and then this part to get to that screw" kind of thing? Any help would be appreciated.
raracah is offline   Reply With Quote
Old 07-30-2007, 06:57 PM   #2 (permalink)
FinalGear's Avatar
View FinalGear's Photo Gallery
Removing Headlights
Study the front bumper assembly...I'm not sure if you have to remove the bumper in order to remove the headlights....
FinalGear is offline   Reply With Quote
Old 07-30-2007, 08:05 PM   #3 (permalink)
Registered User
View sushi_kungfu's Photo Gallery
if i remember correctly, there are a total of 5 bolts each side...ill double check and get back at ya...i just recently took off my brother's 92 corolla dx's headlights to replace...if you want, pm me back to remind me...thanks!
sushi_kungfu is offline   Reply With Quote
Old 07-30-2007, 10:37 PM   #4 (permalink)
Thanks for the response. I messed around with it tonight and eventually found success. I had to loosen the molding that runs between the bumper and the headlights (it's about an inch wide). To get to some of the screws, I had to remove the side running light assembly (2 screws). By loosening this molding, I was able to insert a flat bladed screwdriver under the headlight and pop off the black insert that holds the headlight to a post. There are two more of these that are accessable from the top, but it was this bottom one that had me stumped. Not any more!
Thanks for your help...I'm sure I'll need more.
Looking to purchase a 91 Cressida sedan...have fuel requirement q'n... St/\\\nfeld Cressida Forum 11 02-16-2007 06:03 PM
91 Corolla DX sedan 4a-fe manual transmission questions wc18 Archived Corolla threads 4 10-03-2005 02:03 PM
91 Sedan Starter Swap soccerman58 Tercel, Paseo, Starlet, and Sera Forum 6 09-23-2005 08:15 AM
91 Sedan brake rotors help soccerman58 Tercel, Paseo, Starlet, and Sera Forum 4 09-21-2005 10:26 AM
