Auto to Manual (AE92) - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 08-04-2007, 11:29 PM   #1 (permalink)
SCT
iAzn
SCT's Avatar
Gameroom cash: $302100
View SCT's Photo Gallery
AE92 Auto to Manual (AE92)
Just doing some research... If I were to take out all the shift and clutch cables and linkages from a manual AE92 sedan, would it hook up with a manual tranny that would've come out of an MR2 or Celica? When I do get my 4AGZE, I'm getting it with a 5-spd still bolted on with it that way I can swap both the tranny and engine. Most likely it'll come out of an MR2. So before I spend $, I'd like to know...
AE92 GTS Skirts | AE92 LE Trunk Garnish | 4AGZE Cryo-Blueprinted Crank
!ALSO FOR SALE!
SCT is offline   Reply With Quote
Old 08-05-2007, 07:27 PM   #2 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
gze swap
as far as i know the stock ae92 has a c-class c50 or c52 tranny the only difference is that the e52 usually pulled from a gze is heavier and has slightly different gearing. oh and about 70lbs. it's the same for mr2 and japanese ae92 levin because the transaxle is right infront of motor in both cars! great huh
so to answer your question yes the linkages should fit although some cable may need adjusting, like the throttle etc.
where are you doing this swap?
Im in Florida and i have a 5spd dx sedan too except i was plannin to put the gze into the sedan!
good luck
jmaz87 is offline   Reply With Quote
Old 08-05-2007, 07:54 PM   #3 (permalink)
SCT
iAzn
SCT's Avatar
AE92
I'm up in Maryland. And a hot $800 away from getting a 4AGZE with the 5spd. It'll be awhile before it actually gets done... How do I know whether the tranny is a C50, C52, etc???
!ALSO FOR SALE!
Old 08-06-2007, 11:24 AM   #4 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
AE92
good luck
ok (runnin on memory) i just ordered the entire toyota bible on all usdm 91 corollas so i can verify all of this in a couple of days...
ALL USDM corollas are supposed to have one or the other but for the record i've only seen the C52 i don't think there is any difference.
I'm pretty sure ALL gze's came with the beefier e52 with bigger axles on both levins and mr2.
However i don't know about USDM spec gze's
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
Old 08-06-2007, 05:52 PM   #5 (permalink)
View EverAE's Photo Gallery
pretty sure the ae101s use a e58 (i believe thats what it is). then theres always the fact of whether you get a lsd box or not. im just throwin this question out there, but won't you need to adapt fwd shift cables to the mr2 box since the linkages are from different sides?
EverAE is offline   Reply With Quote
Old 08-06-2007, 06:24 PM   #6 (permalink)
Donald's Avatar
Gameroom cash: $196920
View Donald's Photo Gallery
The MR2 linkage is on the front side of the tranny, while the Corolla linkage is on the rear side. I read that you can swap linkage over to make the Mid engine tranny work on the FWD car, but from my recolection it involves some gearbox dissambly.
Check out this link below.
http://www.wcengineering.com/articles/toyotatrans.html
'88 Corolla, AE92 SR-5 (7A-FE swap in progress)
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 08-07-2007, 12:04 AM   #7 (permalink)
SCT
iAzn
SCT's Avatar
AE92
If the 4AGZE can bolt onto a Corolla's 5 spd and nothing blows at all, then screw the 5 spd from an MR2. Cuz I bought a 5 spd from a junkyard out of a '88 japanese Corolla 4dr with the 4AF several months ago. Which would bolt right into my car since I have an '88 japanese Corolla 4dr 4AF, just automatic. But since I want a 4AG-swap, I'm hoping I didn't waste my time (3 days) and $90 at the junkyard pulling a tranny that's not compatible with an engine that throws down almost twice as much hp than a 4AF.
!ALSO FOR SALE!
Old 08-07-2007, 05:21 PM   #8 (permalink)
i dont know how long a (im guessing c52) will last on a gze. its not really twice as much hp that you have to worry about, its the torque increase. 20V's uses a C series tranny, it came standard with that, and it has 160 hp, the gze has alot more torque then the 4ages and thats whats gonna eat up the gear boxes. why dont you just buy a engine and tranny package, its not that much more expensive and itll save you the headaches. make sure you get the E series driveshatfs as well.
Old 08-07-2007, 09:32 PM   #9 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
All C series will work with any 4AGE and 4AFE, the C series should be able to last long enough providing that you're not doing burn outs and clutch drops at every stop light, best thing to do if you're using a C series transmission with a GZE is to get a heavy duty clutch.
Aaron (4AaronGE) has been running a C52 for a while with his GZE and he's had no problems.
auto to manual 98 v6 mike6466 3rd & 4th Generation (1992–1996 & 1997–2001) 1 03-19-2007 06:10 PM
I4 auto to manual swap...can I use V6 manual or Celica manual? GameDay 3rd & 4th Generation (1992–1996 & 1997–2001) 5 03-18-2007 02:03 PM
need advise quickly, Auto or Manual longevity issues? peterdaniel xB Lounge 2 03-02-2007 10:35 AM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 03:29 PM
Auto To Manual Trade In HELP! Toji Scion Forum 10 04-05-2005 11:52 PM
