timing belt cover - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 08-05-2007, 09:15 PM   #1 (permalink)
Tuskanr's Avatar
View Tuskanr's Photo Gallery
AE92 timing belt cover
Okay so when i bought the car, the timing belt cover was off, i have the top 2 parts of the cover, and the bottom part is on.
Now what is the EASIEST and quickest way to put it back on.
BTW i have a 4age 1988 corolla gts.
Also whats the easiest way to put on the wheel well plastic guard, the one that blocks debris from hittin the accessory belts
Tuskanr is offline   Reply With Quote
Old 08-06-2007, 11:37 AM   #2 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $404350
View eage8's Photo Gallery
uhh, you should just be able to squeez it into place and bolt it up, get a haynes manual, it'll tell you where the bolts are. you don't have to remove anything to put the top 2 peices on.
the inner fender is usually held on by crappy plastic screw things, zip ties work fairly well though.
'81 BMW R65
Old 08-06-2007, 06:48 PM   #3 (permalink)
Tuskanr's Avatar
cool thanks alot for the reply
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 01:26 PM
93 Celica Timing Belt + Distributor Is the Shop telling the truth? jamesbrogdon Celica Forum 16 05-03-2006 06:44 PM
84 Supra 5MGE Timing Belt replacement sasksupra Supra Forum 5 11-30-2005 06:03 PM
Here is a way to check timing belt. shanzhu1 Camry & Solara Lounge 4 11-23-2005 11:25 PM
Horrible noise under timing belt cover Tommy Hardcore Tech and Competition 11 12-27-2004 07:02 PM
