from what i read in the previous posts and all the ideas people came up with, i suggest you bring it to a mechanic you know and/or trust. they can probably diagnose the problem a lot better than a normal person. afterall, most mechanics seen problems we never thought existed. yea, sorry man, but i think bringing it in would be best since you tried everything you could think of.
just to throw an idea out there, are your fuses all ok and not burned out? i actually had a problem where the engine car wouldn't start, but all the electronics worked. however, when i jumpstarted the battery with a mobile car starter/charger, the engine would start. when i turned the ignition off and tried to start it again, same problem happened. so each time i tried to start the car, i had to jumpstart the battery. after a week of this annoying problem, i decided to buy a new battery. the engine started without needing to jumpstart it. but when i was driving on the freeway on my way to see my girlfriend, i noticed that all the lights to my electronics (radio and clock) were getting dimmer and dimmer until you couldn't even see them anymore. however, the motor keep on running, by none of my electronics were showing, so i stopped the car on the shoulder and turned off the ignition. then the engine wouldn't start at all, no matter if i tried to jumpstart OR charge the battery. my mechanic (who is also a trusted family friend) did some prodding and found out that my 60A amp fuse was all burned up and fried. so yea, one small piece affected the entire motor.
