Idle/Hesitation Issues - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 09-27-2007, 11:57 AM   #1 (permalink)
View 92seo's Photo Gallery
I have an 86 Corolla that is an excellent, reliable car with only 97k on it. However, it seems to have an idle/hesitation problem when it gets warm. Let me explain.
When the car gets up to normal operating temperature, or maybe even just a little past the middle of the temperature gauge, it starts to run worse than when it is cooler. Sometimes when you push on the gas pedal it bogs down, not really doing much. You can't give it much gas a lot of times when it gets warmed up, or it will hesitate. Then, seemingly when the fan kicks on, the car will shudder for a few seconds.
I tried turning on the AC to see if I could replicate the problem, and it seems to keep the shudder going the whole time, like when the fan kicks in.
So far we have had a basic tune up done, with new plugs installed. We have tried running better gas in it as well. It also has a new battery in it now. Not long ago the mechanical fuel pump was replaced as well.
Any ideas as to what could cause this heat related issue?
92seo is offline   Reply With Quote
Old 09-28-2007, 12:57 PM   #2 (permalink)
Bump..............hopefully someone will have some advice. I can't figure this out, and I don't just want a mechanic to throw parts at it and charge me for them.
Old 09-28-2007, 02:17 PM   #3 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
what trim do you have?
Rookie_One is offline   Reply With Quote
Old 09-28-2007, 05:05 PM   #4 (permalink)
First, let me correct myself. The Toyota is a 1985 model Corolla. Our 86 Caddy is currently in the shop as well, so I must have got them mixed up in my head.
Anyway, the I think the Corolla is the "deluxe" model. It is a 4 door hatchback, frankly quite ugly, but a good car to this point. I'll try to answer any questions that may come up the best I can if it will result in me being pointed in the right direction.
Old 09-28-2007, 07:56 PM   #5 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Check all the vacuum lines for leaks. Did you replace cap/rotor/ plug wires? Also check your timing in particular check to see if it advances with acceleration. Your idle speed may also need to be adjusted.
90 GP is offline   Reply With Quote
How well are the dealerships handling some of the 06 Avalon issues? kuvasz 3rd Generation (2005-2012) 11 11-15-2007 02:04 PM
17" mojave or chambers - any issues? baselfish 2nd Generation (2005+) 3 03-14-2007 05:46 PM
Anyone with a black tacoma.. issues? teamblend 2nd Generation (2005+) 21 08-20-2006 10:31 PM
95 camry auto tranny issues ziddey 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-08-2006 08:32 PM
My vibration issues Turtleboy 2nd Generation (2005+) 29 12-25-2005 12:20 AM
