Originally Posted by 94_Rolla_Guy
take a look maybe the retards forgot to reattach the rubber hose, or reattached it too low on the filler neck????? otherwise take a look its metal the "instant gas tank patch" from a parts store should work on it if its not too bad or possibly it could be welded (if taken off car)
Oddly enough it is metal... I was rather surprised that it dose not even have a rubber insulation on the inside. I would have though it would be made of a plastic or rubber as well...
Originally Posted by Flashmn
Welding gas tanks suck...
fuel cell time
Although that would be nice it also raises a couple new problems, such as the fabrication of mounts, custom lines and how I will set up the new lines and where will I mount the tank...
It sounds like a rather expensive option this way.
