4AGE igniter questions? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 10-05-2007, 04:26 PM   #1 (permalink)
AE92 AW11
View 89 tercel racer's Photo Gallery
Well my problem is my car wont start. It has no spark. I changed the ecu I changed the distributer, made sure i had power going everywhere yet car still has no spark. So i wanna just bypass the igniter. So my question is that if i take the two wires going from the dist. to the igniter and run it to lets say an msd box on the magnetic pick up side would it work?
89 tercel racer is offline   Reply With Quote
Old 10-05-2007, 05:20 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
if you bypass the igniter, what good would it do. Igniter is the one that turns the negative side of the coil off. Without it you wont get spark nevertheless.
Old 10-05-2007, 06:08 PM   #3 (permalink)
AE92 AW11
Well i heard that if you use the magnetic pickup in the distributor and run the two wires to the magnetic pickup plug on the msd then the msd becomes your igniter.
Old 10-06-2007, 08:13 PM   #4 (permalink)
Gameroom cash: $133855
no.... using a toyota ecu there is no way to bypass the ignitor......
if you think it's the ignitor, then replace the ignitor..... they do go out at times....
and I hope you replaced all of your parts with the correct parts.... 4age's have at least 2 different ignition systems (16V/us) and they aren't comperable......
4age 20valve questions woodenhead72 Archived Corolla threads 9 07-07-2006 10:59 AM
Questions Jayleav 1st Generation (2003-2008) 11 06-04-2006 12:38 PM
igniter troubles? fjkid Pre-88 Toyota Pickup/Hilux 3 04-12-2006 06:14 AM
2000 camry questions dimask 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-06-2006 09:14 PM
4AGE Swap questions |PuNiSh3R| Archived Corolla threads 10 03-05-2004 01:15 AM
