HELP! '92 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 10-10-2007, 01:48 AM   #1 (permalink)
View Bertdogg's Photo Gallery
HELP! '92 Corolla
Hello,
I have an automatic. Whenever I shift from P to REV or D to REV, I get a strange "knock" coming from underneath the passenger side floorboard. It only happens when I shift into REV. The odd time it won't make the noise but most of the time it does. This just recently started happening. Othewise the engine runs great with no slipping and smooth gear changing.No noise problems through hard acceleration or regular highway/city driving.Only when backing out/in of parking stalls basically. Any ideas as to what it could be?
Thank you
Bertdogg is offline   Reply With Quote
Old 10-10-2007, 06:56 AM   #2 (permalink)
blb
View blb's Photo Gallery
Bad motor mount.
blb is offline   Reply With Quote
Old 10-10-2007, 01:15 PM   #3 (permalink)
Really? Roughly how much does it cost to replace this?
Old 10-10-2007, 01:26 PM   #4 (permalink)
blb
It's just a possibility and would be good to have it checked, at least as a starting point. Can't tell you about cost, because I personally never replaced one.
Another thing to check is make sure there is least a fingers width between all exhaust system components and other components. I'm thinking when you are putting it into reverse, the engine is rocking slightly causing something to touch, making the sound you are hearing. If the motor mount is bad, the amount of rocking may be excessive.
Old 10-10-2007, 01:54 PM   #5 (permalink)
One more question. Is this something I can do at home by jacking up the vehicle or does it need to be serviced at a garage.
Thanks for all your replies. You've been a great help!
Old 10-10-2007, 03:29 PM   #6 (permalink)
View tashirosgt's Photo Gallery
Of the 4 engine mounts and one transmission mount, you can replace the side mounts without jacking the car up or having it on jackstands. Whenever you replace a mount you have to put a jack under the engine and jack the engine itself up a few inches. So it won't be as simple as
unbolting and bolting something. You can replace front mount if you are willing to put the car on jackstands and crawl under it to work. Replacing he rear mount and the transmission mount would probably require hoisting the engine up out of the engine compartment.
On a '92, it is likely that some of the mounts are bad, but this may not be the cause of your noise. It could be something like a sticking ball joint that pops loose. You should look at the whole suspension.
Since mounts are the first topic to come up, check them by finding pictures of good mounts ( ebay sellers often sell engine mounts that fit the '90-'93 Corolla). The mount has a cylinder in its center suspended inside an outer metal ring by some thick rubber members. When a mount goes bad the rubber members crack and center cylinder doesn't stay in the center. Also look in the engine compartment while someone revs the engine and see if the engine twists noticeably. That would be a sign of bad engine mounts.
tashirosgt is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
Parting Out '92 Corolla or will Sell Whole Car blb Car Parts for Sale 1 10-09-2007 05:35 PM
New Member with a 92 4EFE Corolla CowboyX Introduce Yourself Here 0 12-26-2006 11:26 AM
Best oil to use '92 Corolla karugs Archived Corolla threads 8 05-15-2005 10:31 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
