Differential Fill Plug - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 10-15-2007, 07:17 AM   #1 (permalink)
blb
View blb's Photo Gallery
On a 1992 Corolla, 3 sped automatic, who has found a good way to get at, and remove the fill plug on the differential? From underneath with a box wrench, from straight back with a socket and u-joint or from the top? There doesn't seem to be any straight shot at it.
blb is offline   Reply With Quote
Old 10-16-2007, 12:55 AM   #2 (permalink)
View GTSTWINCAM's Photo Gallery
I was going to ask the same thing.
Im trying to remove the fill plug on my 97 Corola 3spd automatic.
There is no room to work with.
Let me know if you get it out and what you did.
gerald
1991 Toyota Celica GT-S 5SFE
1995 Nissan 240SX SE KA24DE
2000 Nissan Primera SR20DE
GTSTWINCAM@yahoo.com
GTSTWINCAM is offline   Reply With Quote
Old 10-16-2007, 03:36 AM   #3 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
When i did mine I used a box wrench but can't remember if I loosensed it from the top or underneath. I do remember reinstalling the plug from the top and it is by feel alone and there is barely enough room to fit your hand in that area.
90 GP is offline   Reply With Quote
Old 10-16-2007, 08:33 AM   #4 (permalink)
View tashirosgt's Photo Gallery
On the AE92 AT, it works to use a "offset" box wrench that has a slight bend on the end of handle so the wrench can fit into the slight depression around the plug. I found a double ended box wrench at autozone that worked. It had a different style offset at each end. The end that I thought would work did not, but the other end did.
tashirosgt is offline   Reply With Quote
Rear Diff oil blues.... pdx 2nd Generation (2005+) 214 07-18-2010 05:00 PM
Problem accessing differential fill plug on 1996 corolla DX tritri Archived Corolla threads 2 12-20-2006 02:10 PM
Changing Differential oil cephasiii 2nd Generation (2005+) 93 12-08-2006 05:18 PM
Locker or limited slip Gonefishin 2nd Generation (2005+) 30 06-20-2006 09:28 AM
unknown plug... fe519 Camry & Solara Lounge 4 10-19-2003 05:18 PM
