88 corolla electrical - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 10-15-2007, 05:17 PM   #1 (permalink)
View brake pedal's Photo Gallery
i have an 88 corolla wagon w/AC the start of my proplem was that some genious previos owner wired the radio straight to the battery. this caused a short the other night that melted the speedo needle clean off the stem. ok i have found the source of the short and disconnected it.
now the car starts and runs but nothing works on the accessory side. lights, horn, heater and coolant fans are out. i used a jumper on the relays on the battery post with no effect. i jumped the coolant fans at the relay in the panel on the fender and got a buzzing from the relay marked head and the fans to come on. itried a new relay there and no help.
any suggestions on what to check next? help thank you!
brake pedal is offline   Reply With Quote
Old 10-15-2007, 07:17 PM   #2 (permalink)
Update
traced the radio wire brom battery thru the steering colum around the ignition???? bvut found no burned or scarred insulation.
i did however pull up on the parking brake handle, all accessories came on works good except for the peskie billows of smoke from the dash around the instrument panel. trying to get cover off the parking brake housing tomarrow. eeehhhhh!!!
advice on 88 corolla gen_x Archived Corolla threads 8 03-28-2011 02:46 PM
Colod code corolla -88 (red) please help Elin Archived Corolla threads 1 09-06-2006 02:14 PM
Strange Electrical problem 1997 Corolla CE smharr4 Archived Corolla threads 3 07-12-2006 09:27 AM
88 Corolla with Tercel Transmission? shogun6684 Archived Corolla threads 0 02-03-2005 12:38 AM
Corolla 88 with 4A-F problem george Archived Corolla threads 13 03-20-2004 03:10 PM
