1980 Headlight conversion? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 10-15-2007, 08:48 PM   #1 (permalink)
View Penny's Photo Gallery
Recently bought an 81 and found the 80 front end. I am ready to make the conversion to the quad lights but noticed that the quads have 2 plugs and the old lights only have 1 each. I have been told tht that 1 of the lights on each side of the quads are for high beams. Has anybody done the conversion? How should I go about making them work correctly?
Thanks
Penny is offline   Reply With Quote
Old 11-21-2007, 05:12 PM   #2 (permalink)
View corollamark's Photo Gallery
corolla headlights
On the dual lights iner lights are the low beam and the outer lights are the high beams. I think that you can cut the wire on the dual lights where it makes one wire and put that on your wiring.
corollamark is offline   Reply With Quote
Old 11-21-2007, 05:32 PM   #3 (permalink)
View gaijin71's Photo Gallery
iirc, one pair of the quad headlights are for highs and lows. it's the ones closest to the corner lights. the other pair is for highs only. you could splice in the plugs for the high beams to the stock headlight wires.
gaijin71 is offline   Reply With Quote
Old 11-21-2007, 05:38 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
if you want both lights to operate simultenously, you're going to have to do two relays on each side...
Also you gotta remember, toyotas switch the ground, not the positive. On the H4, theres a common positive and switchable ground.
I just did this relay mod on my AE92.
headlight conversion mike6466 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-07-2007 03:01 PM
Headlight Harness (6054 to H4 Conversion) arcasmachineracing MR2 Forum 13 11-22-2005 05:14 AM
1989 Headlight Conversion?? One_*_Star 89-95 Toyota Pickup/Hilux 7 11-18-2005 04:01 AM
headlight conversion MKIII/MA70 reflex92 Supra Forum 2 08-06-2004 11:51 PM
headlight conversion possibility mean_green Camry & Solara Lounge 4 06-20-2002 05:12 PM
