85 GTS project and i need suggestions - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 11-23-2007, 11:03 AM   #1 (permalink)
View Spartan7's Photo Gallery
well hows it going guys ? well im a noobie to corollas once again, havent had one since i was 13 and 10yrs later i have one again...all i know is ROTARY"S...well i want to go ITB on my corolla and have atleast 220whp (all motor, if its possible)
here are my questions
what kind of ITB's?
can i put a 20v motor in the rolla
what kind of cams
what kind of compression
and wich motor is better the stock gts motor or the 20v
i know these are a lot of questions but i really need your help guys...thanx
and the car is going to be build for drifting, just incase anyone was wondering
Spartan7 is offline   Reply With Quote
Old 11-23-2007, 01:59 PM   #2 (permalink)
YYYOOOOUUUUHHHHHHHOOOUUU!
Rookie_One's Avatar
View Rookie_One's Photo Gallery
220 HP, better get youre hand already in your pockets, because it wil cost ya!
Rookie_One is offline   Reply With Quote
Old 11-23-2007, 06:34 PM   #3 (permalink)
View EverAE's Photo Gallery
if your planning to get those numbers with a 20V, your looking at a good chunk of money, i know getting past 200 hp on a 20V gets very expensive (not that getting to 200 is cheap...). your looking at pretty lumpy cams, higher compression pistons, headwork, gooood management, open throttles, yadda yadda. plus itll blow for street driving if your planning to keep it legal. my suggestion is if your serious, what about a 3sge beams blacktop w/ 6speed. the engines more expensive, and teh swap is more difficult, but itll be easier to reach your goal, and the extra 0.4L of displacement wont hurt at the track.
EverAE is offline   Reply With Quote
Old 11-24-2007, 10:50 AM   #4 (permalink)
oh ok kewl...so what HP do u think it will be good for daily driving
Old 11-24-2007, 05:07 PM   #5 (permalink)
it all depends on your set up really, if you have really lumpy cams with alot of duration your gonna have all your power up to, and a bumpy idle. a TRD headgasket to bump the compression up, a good set of cams (research on what specs would suit your needs), open throttles, nice exhaust (possibly header), and something to manage it would make a fun and quick street car..
Old 11-24-2007, 06:18 PM   #6 (permalink)
operation boro thunder
View project trueno's Photo Gallery
20V 4AGs in stock form are already peaky in nature. Big cams with proper timing and ECU map to match, will render the vehicle useless on the street. This applies to heavily modified 16Vs and 20Vs.
"oh ok kewl...so what HP do u think it will be good for daily driving"
having 100, 150, or 200 HP makes no difference on the street if the engine has no torque. If you build a 220WHP 4AG, are you going to rev it to 9k rpm+ every gear? Not exactly practical in terms of daily driving.
A stock 20V has ITBs, performance equivalent to a mild modified 16V, with dependable reliability. If you have a bigger budget with access to fabrication equipment, larger displacement engines such as the 3SGE, SR20, or even F20/22C becomes an option.
project trueno is offline   Reply With Quote
