'86 corolla Won't stay running in Drive - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 11-28-2007, 12:16 AM   #1 (permalink)
View redfisher69's Photo Gallery
USA '86 corolla Won't stay running in Drive
new fuel pump, re-built carb, new fuel filter, new wires, new plugs, new rotor button, new cap, new coil, just started to run like crap after all this. will stay running when put in reverse. intermitant miss, stumbles on initial throttle up and then snorts and bucks till it reaches high enough revs then it will keep running but still with interminant miss, backfires a little, checked/replaced all vacume hoses to vacume advance. need to perform Ether check. Put in fuel treatment and filled take with preimum gas. NOTHING is working. N E sugestions?
redfisher69 is offline   Reply With Quote
Old 11-28-2007, 09:47 AM   #2 (permalink)
View wiccanferret's Photo Gallery
Did you do all this in one day or something? If not, at what point did it start running like crap?
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 11-28-2007, 10:00 AM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
either its a fueling problem or an ignition problem. I'm thinking the latter.
Flashmn is online now   Reply With Quote
Old 11-28-2007, 04:16 PM   #4 (permalink)
All new things that have been installed were done prior to it starting to run like crap 'cept the new vac hoses going to the vac advance. I went after work and retrived it and when I started it it ran like it did last night then cleared up. Drove it home and it ran like a toyota does. Just humming along. I think the STP fuel treatment and the premium gas hopefully remedied the problem. If it starts to run like crap again before I get gas again then I'll know the problem is not fuel. But then again it could be in the delivery of the fuel and/or ignition problems. Have anyone of you heard about a vac diaphram having an intermitant prob? I can't see a timing prob that fixes itsself. Maybe trash in carb but I just recently rebuilt it and the filter is really flowing fuel fine. The fuel treatment had all night to sit and do its job. Maybe when I started it the last bit of fuel that was bad in the carb got flushed out and the treated gas is now flowing thru it. Who knows!!
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 06:19 PM
WTB- 86 Corolla or an 86 Corolla engine (Hamilton ONT) KatzY Car parts for trade or wanted parts 0 12-11-2006 04:41 PM
Corolla rattling noise near drive belt area Momaru Archived Corolla threads 8 09-07-2006 01:57 AM
