20v with oil cooler ????? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-08-2007, 01:25 AM   #1 (permalink)
dori-oni's Avatar
View dori-oni's Photo Gallery
ok on the refferance page this is what it states "AE86's "reserve pressure" oil cooler block should be removed as it's pressure retention spring can drop the oil pressure. Use and aftermarket "positive feed" oil block and larger aftermarket oil cooler for best results. VVT thrives on the high oil pressure to move quickly in and out of position so never do anything to drop the pressure in the 20V."
so my question is can i use the factory gts oil cooler with an aftermarket sandwich plate?????
dori-oni is offline   Reply With Quote
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 02:17 PM
Bôsôzoku style oil cooler driftonedge Off Topic 1 11-05-2007 09:36 AM
high pressure oil cooler leaks after new gasket? chicagocurtis 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-24-2007 12:57 AM
Supplemental engine oil cooler with tow pkg missile-29 2nd Generation (2005+) 7 01-02-2007 08:15 PM
Oil Cooler Install Questions racerhex General Discussion 0 10-09-2002 10:47 AM
