need some help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-18-2007, 11:50 PM   #1 (permalink)
prjkt:jdmidnight
View piso's Photo Gallery
need some help
so, i recently bought an ae85 coupe sr5. i already know the motor is the 3A carb'd motor, and the rear brakes are drums, and the transmission is a steel-cable tranny, and the rear diffy is a 6.38" instead of a 6.7". what i need help with is figuring out what else differs this car from an ae86. basically, im trying to convert from ae85 and make it an ae86 (and the motor will be swapped anyway). please and thankyou
piso is offline   Reply With Quote
Old 12-19-2007, 04:28 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
You sure its an AE85, because those were japan only. US versions are AE86 with a 4A-C engine and the transmission doesnt have cables, only cable goes to the clutch, because those are FWD only.
Flashmn is online now   Reply With Quote
Old 12-19-2007, 05:51 PM   #3 (permalink)
prjkt:jdmidnight
almost positive its an ae85 unless the ae86 came with drums in the rear as an option. i mean, the chassis code says ae86 but i heard that the ae85 says the same thing.
Old 12-28-2007, 01:00 PM   #4 (permalink)
View gekishibu86's Photo Gallery
AE85 chassis code Corollas were never officially imported here in the US. Main difference between the two is as you mentioned is the cable actuated clutch and the 3A motor. What you have in your possesion is an AE86 chassis code Corolla. Look at the firewall at the passenger side by the heater valve, it will read AE86-XXXXXXX. AE86 chassis code Corollas did come with drum brakes(SR5 trim with the 6.38" diff and 4AC) and disc brakes(GT-S trim with the 6.7" diff and 4AGE).
gekishibu86 is offline   Reply With Quote
