High idle problem w/ my 86. Weird problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-20-2007, 04:14 PM   #1 (permalink)
View bjamick's Photo Gallery
Ok guys i've had this problem since i've owned my car. Its an 86 corolla 4 door FWD and only has 135k miles on her. Well the problem i've been having is when i turn on my headlights the cars idle will raise alot. But when the lights are not on it idles just fine .. I have no clue what could possibly have happened but i know its hard to stop the car sometimes bc the car is at like 1/8 throttle when the lights are on. I know headlights dont pull vacuum so what in the world could this be??
Also, my passenger side brake light will not work. Its like this, if the headlights are off the brake light doesn't work, but if i turn the lights on the light comes on but its just the running light. And when i hit the brakes the light still doesn't light up . I've replaced the bulb and i know it works bc if it didn't it wouldn't light up at all im sure. So the only one working properly lights on or off is the drivers side light!!
Anybody know what the problem might be??
bjamick is offline   Reply With Quote
Old 12-21-2007, 01:07 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Not sure about your idle problem, but with the brake lights it sounds like a wiring problem.
Old 12-22-2007, 08:32 PM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
In some years they use vauum. Are you sure your year does not use a vacuum idle up switch to increase idle with headlights turned on? a vacuum leak can do that.. or a vsv valve which changes vacuum with a switch..
retiredat44 is offline   Reply With Quote
Mod Please Delete AznVR4 5th & 6th Generation (2002-2006 & 2007-2011) 0 03-21-2007 02:29 PM
Idle problem deeps Celica Forum 2 01-03-2006 01:16 AM
high idle problem 93twinstick General Discussion 4 11-04-2004 01:50 PM
