Starting Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 01-05-2008, 12:50 PM   #1 (permalink)
View AE86_1984's Photo Gallery
Starting Problems
I went out today to start my 1984 ae86 and it wouldnt start it would turn over a little bit but ended up making a dieing sound and not starting...the lights and the other acessories were goin so i dont think its the battery or the alternator...im thinking its the starter...any feedback would be great...thanks
AE86_1984 is offline   Reply With Quote
Old 01-08-2008, 11:12 AM   #2 (permalink)
View Rivan16's Photo Gallery
Troubleshooting steps...hope they help:
-With a multi or volt meter, attache lids to battery terminals...read voltage as someone else attempt to start it...if volts reading drops below 10voltsDC, you battery is bad!
-If the voltage stays above 10 volts and the starter "click" and do not turn, use a broom stick and hit the starter as someone attempt to crank it...if it starts, you may need a new starter OR battery cables going to the starter. Before you buy a new starter get it checked by Auto Zone or Advance.
Good luck!
Rivan16 is offline   Reply With Quote
Old 01-09-2008, 05:20 AM   #3 (permalink)
just took it to autozone and they said that it was the alternator...its conducting electricity but isnt makin it back to the battery to charge it
99 v6 starting problems bronxstreets 3rd & 4th Generation (1992–1996 & 1997–2001) 11 12-12-2007 01:16 PM
Problems starting 94 toyota tercel Gordon Tercel, Paseo, Starlet, and Sera Forum 27 08-26-2006 12:58 PM
starting problems tacoma-05 2nd Generation (2005+) 68 04-28-2006 05:42 PM
1991 Corolla has Occassional Problems Starting PoopEater Archived Corolla threads 5 01-08-2006 07:22 PM
starting problems mr2trbo93 MR2 Forum 9 06-13-2005 12:26 AM
