CA engine smog question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 01-23-2008, 11:38 PM   #1 (permalink)
View Hatchi-san's Photo Gallery
Hey every one!!! I'm new here. I wanted to ask if anyone here knew if it was California smog legal to put a fuel injected 4age in a
1987 SR5 Corolla coupe . Since it came carbed. :'(. And is it easy??????
Hatchi-san is offline   Reply With Quote
Old 02-07-2008, 09:45 PM   #2 (permalink)
View Dra6on45's Photo Gallery
technically it is legal and will pass smog as long as you put everything relating to smog from the 4age donor car into the other car and also the engine has to be from a newer model corolla than your current car. About the ease of the swap I'll let someone else chime in as I am not too familiar, although I heard the worst part is the fuel injection system. Hope that helps. All the smog equipment has to be there and fully functional.
Dra6on45 is offline   Reply With Quote
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 77 02-04-2011 07:08 PM
Avalon Engine question osot 1st Generation (1995-1999) 0 10-10-2006 11:55 PM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-06-2006 12:28 AM
