maf on 20v with itb's - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 02-01-2008, 02:17 AM   #1 (permalink)
prjkt:jdmidnight
View piso's Photo Gallery
AE86 maf on 20v with itb's
so, i just got my 20v s/t and its got the itb's (obviously) however, my concern is how to get the induction box off and run 4 open (well, 4 filters) an d use this setup with the maf. leaving it hanging would make the engine run like complete s*** correct? so if i want 4 open throttles, how do i fix that problem? thanks
piso is offline   Reply With Quote
Old 02-01-2008, 02:50 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
your engine wouldnt run at all if the MAF was "hanging around"
Flashmn is online now   Reply With Quote
Old 02-01-2008, 12:00 PM   #3 (permalink)
View EverAE's Photo Gallery
20V silvertop doesnt use maf, its use afm (airflow meter). the car wouldnt run, as the name suggests the airflow meter reads how much air is goign into the engine, therefore your computer wouldnt know how much fuel to add.
to remove the afm and run open throttles you need to convert the engine to MAP sensored, either by converting to a ae111 ecu and harness (youll need a piggyback for this as well), or a standalone.
EverAE is offline   Reply With Quote
Old 02-01-2008, 12:36 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
yeah, a bunch of trouble and no substancial gains of any kind...
Old 02-01-2008, 12:37 PM   #5 (permalink)
prjkt:jdmidnight
meant to say afm, my bad you guys. but yea thanks, might just have to figure something else out
Old 02-02-2008, 03:17 PM   #6 (permalink)
its not huge trouble to convert it, just money. much cheaper resolution would be a megasquirt if you have some time and experience.
you do get gains, you could expect close to 10 whp gain on a stock engine, and obviously more if you were planning more mods (ie, hotter cams).
Old 02-02-2008, 05:09 PM   #7 (permalink)
prjkt:jdmidnight
toda cams are on the way anyway so...we'll see. basically doing alot of work to the head for now after i get the thing dropped in
Old 02-02-2008, 08:27 PM   #8 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
you don't need a piggyback to run an AE111 ecu on a silvertop. I have a silvertop in my MR2 and have been running off of a blacktop ecu for a year now with no problems and there are a bunch of other mr2 owners that run the same setup. If you convert to an AE111 blacktop ecu you will need to change some of the wiring and get a map and ait(air intake temp) sensors.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 02-03-2008, 07:21 PM   #9 (permalink)
people ive talked to who did the ecu swap found it necessary. whats you a/f ratios look like.
Old 02-03-2008, 07:44 PM   #10 (permalink)
SCCA Tech Services
I have never dynoed mine but there are plenty of people on the MR2 board that are running silvertop motor with blacktop ecu and no piggyback and none of them have any problems.
Brian Harmer
Old 02-04-2008, 12:22 PM   #11 (permalink)
you wouldnt really have problems, im just saying the whole reason ive heard you need (read: want) a piggyback on teh conversion as it will f-up your a/f ratios. which is understandable, condisering the blacktop has 0.5 higher compression, more aggressive cams, etc.
Old 02-04-2008, 12:30 PM   #12 (permalink)
SCCA Tech Services
Yes you are correct you will probably want one. What I am saying is you don't need one to run with a silvertop. The motor still runs great and strong without one. Like you said though the a/f probably isn't what it should be but for most people it is good enough.
Brian Harmer
