87 FX16 vibrating/rough idle - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 02-06-2008, 04:10 PM   #1 (permalink)
View Ladyfsh's Photo Gallery
Once the car is completely warmed up, the vibration is pretty bad at a complete stop. It seems to be primarily focused up through the steering column. Because of age and suggestions from many others, all motor mounts were changed, we also increased the idle. Did the first 3 mounts and did not do the last one because the mount looked fine. The vibration improved, so we decided to do the last one. This has now made it even worse. Increasing the idle helped some, but when you add any load, it bogs down. Going from Park/Neutral to drive, it drops. Add in turning on the lights, it drops more. Turn the wipers on and drops even more. Tested the battery and alternator and both tested fine. Need suggestions.
Ladyfsh is offline   Reply With Quote
Old 04-08-2008, 08:27 AM   #2 (permalink)
View openflame06's Photo Gallery
Considering when you turn certain things on that use power it makes the vibration worse I'd be looking for a short circuit somewhere. Or, i'm not sure how you tested the battery but the battery a lot of the time will start the car and seem fine but when load is increased begin to fail.
If the amps on the battery are low when the car is stopped I'd say its time for a new battery.
openflame06 is offline   Reply With Quote
