Corolla 77 neutral safety switch ? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 03-21-2008, 06:16 PM   #1 (permalink)
View turbomustang84's Photo Gallery
Where is the neutral safety switch located on the mid 70's corolla's with an automatic tranny ? I removed the shifter and nothing is there .
is it located in another spot ?.
I have a feeling it went out because the back up lights quit working and also the starter does not do anything .any help will be appreciated
turbomustang84 is offline   Reply With Quote
Old 03-21-2008, 09:51 PM   #2 (permalink)
View toyomoho's Photo Gallery
Not up on this car but there might be a switch located behind the shift arm on the transmission. Back up lights typically have another switch screwed into the trans housing or it may be included with the other switch. If more then one issue might be a wiring problem.
