Originally Posted by piso
and the differences before and after 85... body detailing, maybe a little modification to the motor but not much, and some things differed between the gts models and sr5 models but i mean, not too much
I don't think you can be much more wrong.....
for the ae86....
the gts had a 4age, 16V, EFI engine (twin cam), higher compression.... the interior is different, the fuel tank/pump/lines are different, the rear end is different, the rear has disc brakes, an LSD option, and all were 5 speeds
the sr5 had a 4ac, single cam 8V, carb motor, less boulstered seats, smaller rear end, and rear drum brakes, no lsd rearend availability, and they came as both an at and a 5 speed....
that all being said, I just picked up an 85 SR5 coupe, AT.... but the price was right
