86 4ALC Overheating
Ive got a CS-X seca, 86 model with the 4ALC Engine.
Recently it had the carby off and the vacuum lines were put back on wrong - this has been fixed up now though.
The car is overheating and I was wondering what other peoples experience has been with this - in Gregorys service manuals theres quite a bit that can cause it, vacuum lines the vacuum switches etc
With the thermostat out of the car theres no overheating, but as soon as it is back in the temperature goes to caution as soon as i drive up the street.
I have checked the cooling fan - its on constantly so in the next few days i'll be getting another thermoswitch to try. - As i mentioned earlier ive checked all the vacuum lines, but im getting another thermovacuum port as well just to rule that out.
Blown head gaskets - my dad pushed air through the cylinders using a valve designed for going into the spark plug ports and there was no bubbling in the radiator.
Water pump is brand new, so it shouldnt be the issue
Radiator - Doesnt seem to have any blocks in the cores
If anyone has ideas of anything else to check it would be great because I've almost gone through everything I think would be causing the problem.
Thanks guys
Reason: forgot to mention new water pump
