1976 Corolla ignition problem
Hi,
I have a 1976 Corolla , 2TC engine. I need help troubleshooting a problem where the car won't start. Appears to be a problem with the ignition system. The symptoms are when the key it turned to the "start" position everything seems normal, the engine fires right up, however, as soon as I release the key back to the "on" position, the engine no longer fires and dies immediately. It seems that when the key is in the "on" position the ignition system is no longer providing ignition to the engine. Any ideas?
/RV
