corolla over heating - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 05-01-2008, 02:15 PM   #1 (permalink)
View bobwest's Photo Gallery
any help on why the car keeps overheating. i changed the radiator, pump, thermostat, flushed the coolant, and added an electric fan. it is still overheating with the a/c on. any help would be appreciated. thanks, bob
bobwest is offline   Reply With Quote
Old 05-02-2008, 03:11 AM   #2 (permalink)
View rickhart's Photo Gallery
Depends on what you mean by "overheating". The range for normal temp on the temp gauge is wide, so do you mean that is is close to boiling over ?
My '86 AE82L has ALWAYS run hotter with the A/C running but much less so after I did the following---replaced the temp control switch (turns on the fans) because it wears out and gets slower to respond to the heat, run 65% distilled water/35% long-life coolant, installed coolant-hose shunt as described in my other post, run 91 (mid-grade) octane during hot weather, set A/C switch to ECON rather than to MAX.
Hope this helps.
rickhart is offline   Reply With Quote
Old 05-05-2008, 09:42 AM   #3 (permalink)
EJ86's Avatar
View EJ86's Photo Gallery
AE86
there's several possiblilities:
blown head gasket:
-is your engine running sluggish
-u see white smoke
Resolution:
-check all your fluids
-check for leaks
-do a compression test
bad temp sensor(does your temp move up and down/doesn't stay constant):
-loose wire
-bad plug
Resolution:
-find the wire and check the condition
-1985 Toyota Corolla GTS (2dr)
http://www.cardomain.com/ride/561054
EJ86 is offline   Reply With Quote
