tires for 15x7 rims??? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 05-05-2008, 10:38 PM   #1 (permalink)
View toyota95's Photo Gallery
What would be the best tires size for 15x7 rims???
195/55/15 or 205/50/15???
yes..I want to lower the car maybe 2" or less someday..
Again this is my first ever AE86 Coupe..
Thanks guys..
toyota95 is offline   Reply With Quote
Old 05-06-2008, 10:16 PM   #2 (permalink)
anyone?
Old 05-07-2008, 03:29 AM   #3 (permalink)
View 92MX83's Photo Gallery
205/50-15, but your offset needs to be correct, like +23 or lower.
"Crush enemies, see them driven before you, and hear the lamentation of the women!" - Conan the Barbarian, on what is good in life
92MX83 is offline   Reply With Quote
Old 05-07-2008, 08:46 AM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $272921
View REN69's Photo Gallery
Depends.. a lot of the AE86 guys I know usually go with the 195/50-15 tires on their wheels when they're 7 or 8 inch wide. Offset has to be low though, most of them go with 0 (zero) offset wheels to get them to fit right.
REN69 is online now   Reply With Quote
Old 05-07-2008, 04:47 PM   #5 (permalink)
thanks guys...
on the box of the rims it stated the offset at 15...
so I'm guessing offset is 15..
hope that help out a little......
Old 05-08-2008, 12:13 AM   #6 (permalink)
well?? offset: 15...
Old 05-08-2008, 10:14 AM   #7 (permalink)
KDM is in
REN69's Avatar
go with 195/50-15s up front (not 55s) and 205/50-15s on the back.
Remember.. this is not tech support, we're not here 24hrs a day waiting for your call, people will answer when and if they can.
You need to do your own research, do searches and read up on other threads and what people have used or can use on their cars.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 05-09-2008, 09:27 PM   #8 (permalink)
yes I did read...And I even ask in other forum to make sure..
And I understand that I'm not here 24hrs also..
Thanks...I appreciated the respond..
Old 05-11-2008, 09:21 PM   #9 (permalink)
KDM is in
REN69's Avatar
post pics of when you're done, I'd like to see what came out of this.
Old 05-21-2008, 12:58 AM   #10 (permalink)
yes I will...soon...
Old 06-26-2008, 12:06 AM   #11 (permalink)
Originally Posted by LChineze View Post
like what most people suggested, you can go with either 195/50s or 205/50s. but before i go on seconding their opinion, there are other things you need to look into. for example, if you plan on going with 205s and later lowering your car, you have to make sure there is enough clearance space to prevent rubbing during turns and suspension travel. the other thing is more cosmetic, like how much the 15 inch wheels fill up the wheel well. if you plan on lowering the car a lot, going with 195 or 205/ but 45 profile tires will give the car a really nice look.
if you want the racing look, go with side profiles 50 or less. 55 will look a bit chunky unless you don't mind it. the setup i have on my 87 corolla sedan (AE83) are 195/50/15s and i had my springs cut (i couldn't find any suspension parts) about 2-3 inches. it really looks good but i do scrape over high bumps.
post some photos right now
I haven't brought any tires yet. Lowering springs(1.8 drop) just came now just waiting for the stocks/struts.
Do you think 205 will rub?
pics?
Old 07-05-2008, 02:06 PM   #12 (permalink)
KDM is in
REN69's Avatar
You haven't bought tires yet??? LOL!
Old 07-07-2008, 12:40 PM   #13 (permalink)
on full afterburner
Gameroom cash: $1344797
I would get the 195/50s just to be safe.
Old 07-10-2008, 05:25 PM   #14 (permalink)
No not yet........wedding is coming up so I have to hold it..
Old 07-16-2008, 12:04 AM   #15 (permalink)
operation boro thunder
View project trueno's Photo Gallery
205/50/15 on a 7" wide wheel, zero offset will be REALLY tight. Prepare to do a bit of wheel arch bending and/or cutting. The performance is WELL worth it however. And because 205/50/15 is an extremely common size (Honda camp), tires are readily available and cheap(er).
If you're worried about clearance and rubbing, stick with +ve offset wheels and 195/50/15. And don't lower too much.
project trueno is offline   Reply With Quote
