GTS 5-spd trans. on a '4a-c' engine? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 05-11-2008, 01:28 AM   #1 (permalink)
View jeenyus's Photo Gallery
Would it work?
Jason
jeenyus is offline   Reply With Quote
Old 05-11-2008, 09:13 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $272921
View REN69's Photo Gallery
yes
REN69 is online now   Reply With Quote
Old 05-11-2008, 09:55 PM   #3 (permalink)
Gameroom cash: $133855
actually it depends on the application.....
if it's for RWD..... the t50's between the GT-S and non GT-S (sr5, and 83's) aren't quite the same... they have different bellhousings.... both will work with one another, but if you get a gts trans then you will need a gts slave cylinder and will have to re-route the lines to the other side of the trans...
if it's for FWD, then yes it will work
Old 05-11-2008, 11:19 PM   #4 (permalink)
Yah i'm doing it to my 84 sr5 with a 85-87? GTS
So it is RWD.
Is that very hard to reroute etc?
Old 05-13-2008, 07:37 PM   #5 (permalink)
prjkt:jdmidnight
View piso's Photo Gallery
clutch forks and fluid lines are on oppositte sides due to the different exhaust path of the sr5 (intake and exhaust manifolds are on the same side). works and from what ive heard personally it isnt too hard just like everything else it takes time
piso is offline   Reply With Quote
